Strange Squeal under load at 2k rpm and about 20psi
Stange noise that only happens at part throttle 2k rpm, 20ish lbs of boost. Just replaced the engine, has all new gaskets on exhaust, all new bolts, torq properly.
I found a few threads on google with similar things. Let off gas noise goes away, go WOT or heavy foot and it goes away.
Anyone run across this?
Thanks all!!
B
Thanks all!!
B
FYI per other threads I rechecked the bolts on the Y pipe, sure enough I had a loose one after the first couple heat cycles . Tightened it down with the "6.4 turbo socket" from snap on and the half moon wrench from snap on (best money I've spent on this ****) noise is gone.
Thank you Google and ford-trucks!! Now on to this extra ground strap location ....
B
Thanks all!!
B
B
Thanks all!!
B
mbrandeskc
1999 to 2016 Super Duty
07-02-2013 12:58 PM
