4R100 Transmission Flush & Tcase too
We're all seen Mark's 4R100 tranny service how to.
2004 F250 5.4L Transmission Flush
The one above from JM has a few more pics. This thread serves as a reminder to get yours serviced. It's not a difficult job. While down there, go ahead and get 2 more qts for the transfer case. Mine (tc) was pretty dark after 60K miles.
Anyone know what this orange sticker in reference to? http://www.thedieselstop.com/faq/949...les/992111.pdf
What happened to the seal between them that was there from the factory? Why did you remove it? How do you control the fluid level in each without this seal?
The dam allows transmission fluid to pool in extension housing. However the two "can" exchange fluid when that pool overflows the dam.
If you don't believe me try to buy a seal....all you will find are seals for 2wd models. I know I bought 2 seals from NAPA, assuming one had to fit because NAPA could not figure out which one I needed. After all was apart....no seal. Not even a place to put a seal.
See for photo:
http://click-a-part.com/products/4r1...ant=9996994052
Note the weep hole at bottom of "dam" in extension housing.
Mark, you are the expert when it comes to transmissions, and I defer to your expertise from numerous posts, so if I am somehow wrong please educate me...thanks
Cowboy350
04-02-2005 03:24 AM
bust7015
03-31-2003 11:24 PM
