2006 F150 Air Conditioning Only at High RPM
Hello,
I have a 2006 F150 4.6 175,000 miles in pretty good shape and well maintained.
Lately, the A/C has acted weird. When I first turn it on, it blows air, but the air does not chill until I have a pretty good RPM going. Then it's fine. Once it starts chilling, it's good to go even when RPM is low (like at a red light). It's just the initial acceleration.
Can anyone advise?
Thank you
Can anyone advise?
Thank you
Hello,
Can anyone advise?
Thank you
Can anyone advise?
Thank you
Have the pressures checked - you might just be a little low on fluid.
It blows air because the fan is blowing - you need to see if the compressor is engaged.
When diagnosing a problem, it is always best to start with the basics and then add complexity as needed. Otherwise you may be chasing werewolfs because the moon was full when the "problem" started.
Hello guys, I'm all fixed up, thank goodness, as we head into hot Texas summer.
Here is what my mechanic emailed me:
The truck was slightly low on refrigerant. The spec. is 2.25lb, and it had 1.60lb. at this level you would not notice a problem until the outside air is over 85 degrees with high humidity. All is good now, I filled it to the correct level, and did not find a leak, more than likely it’s a very slow seep, that might take over a year to leak back down.
dixie460
07-30-2017 09:25 PM
AD5554
10-25-2010 06:15 PM
f150johnny
07-30-2002 08:38 AM
