1964 f350 parts needed
Old 07-03-2016, 08:44 AM
Windsor1966's Avatar
Windsor1966
Windsor1966 is offline
looking for some help . just picked up a nice 1964 f350 2 wheel drive 4sd with factory dump last week and have come up with a small list of parts I can not find
shifter boot
ebrake boot
complete window seal kits
im also looking to upgrade the brake on this truck . I see most sites offer a power brake kit but are they just universal kits or do they bolt in . also I cant find any info if disc brake can be converted on to this truck . was thinking later kinpin trucks with disc brakes could fit but have found no supporting info . also has anyone put power steering in one of theses , truck drives great but its a hand full being a 1 ton truck . thank you again
Old 07-03-2016, 02:06 PM
555 Studio's Avatar
555 Studio
555 Studio is offline
Did you avoid the widowmaker wheels? I can't tell from the photo. Very cool truck!
Old 07-03-2016, 04:25 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Windsor1966
Just picked up a nice 1964 F350 2 wheel drive T-98 4sd with factory dump last week and have come up with a small list of parts I cannot find:
shifter boot = No such thing.
ebrake boot = See below.
Complete window seal kits.
Weather Strips are the same as 1961/66 F100/250 and all have been reproduced by Carpenter.
C1TZ-2A713-A .. Parking Brake Lever Boot-Use with 4 speed / 8 19/32" long x 6 11/16" wide with 6 holes / Obsolete
Applications: 1961/66 F350/700 / No Ford dealer or obsolete parts vendor has any.
F100/700's with T-98 4 speed have a foam rubber pad that fits below the floor pan, acts as a dust shield.
No such thing as a factory dump bed. The only beds available for 1961/66 F350's: 9' Express Flareside & Styleside; Platform (Flat Bed) & Platform & Rack (Stake Bed).
Old 07-03-2016, 07:48 PM
Windsor1966
Thanks for the replys no widow rims . This is my first vehicle I am restoring . In my 20s and started restoring bike a really liked this truck . Number dummy you are right after removing some of the crap in the Truck I did notice there was nothing missing for the shifter area . That's what I thought for the e brake boot. Do you know if any other trucks boots kind of fit or are close . Also I am having a hard time getting it in to gears grinds some times and I can not get it in to reverse . The shifter does twist so I don't know if that has something to do with it thanks again guys any insight is much appreciated
Old 07-03-2016, 09:53 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
You're unfortunately mistaken about your wheels. They do have the Firestone RH-5° widow maker outer rims. The fact that you don't see a separate locking ring is the definitive sign. Picture and diagram below. Remedies exist. Tubeless 17.5" or 19.5" wheels were made and optional for the 6 lug x 7.25" pattern, but not so easy to find. Can also have your center discs pulled and remounted into new tubeless 17" rims by places such as Stockton Wheel. Stu
Old 07-04-2016, 06:12 AM
Windsor1966
Idk if it makes a difference but this is a Canadian truck . I looked hard a the rims and can't see a difference between and a 2 piece I've seen before. They are 17in rims tubeless tires . I work at a shop in town will take one off and dismount it here at work
Old 07-04-2016, 06:56 AM
truckdog62563
Canadian doesn't change anything. Pull the valve cores before screwing with them. Stu
Old 07-04-2016, 09:22 AM
NumberDummy
That's what I thought for the e brake boot. Do you know if any other trucks boots kind of fit or are close?
Also I am having a hard time getting it in to gears grinds some times and I can not get it in to reverse.
The shifter does twist (it shouldn't), so I don't know if that has something to do with it.
I gave you the applications for the ebrake boot. Here they are again: 1961/66 F350/700.
The T-98 4 speed shift lever retainer cap threads off/on. Once it's removed, a roll pin (7B125 in pic) is visible within the threads that locks the shift lever in place.
Place the shift lever in neutral, remove the cap and take a look-see.
Old 07-04-2016, 11:39 AM
Windsor1966
Ok will do . I do believe your right about the rims it sucks will have to sit on that one for a bit to determine what I will do there. Thanks again for the info I went a head and pulled that cap off the pins intact but is worn down alot. Going to cut up a drill bit when I get home and see if that works . Would that really prevent me from getting in to reverse?
Old 09-22-2016, 12:34 PM
Windsor1966
Want to thank everyone for the great advice thanks again . I'm thinking of swapping out my dana 70 in the bake for a later dana 70 with a 8 bolt pattern . Would like to know if there is a later year model I can look for to steal a rear axle out of that would bolt in place. Was also looking at the front brake. Has anyone done a front disc conversion on these truck with out swapping the front axle. And is there a brake boost and master comb that bolts in place ie aftermarket or later year. Thanks again guys .
Old 09-27-2016, 07:04 AM
Shadowrider123's Avatar
Shadowrider123
Shadowrider123 is offline
F350s had an optional power brake booster, parts are hard to find.
Your out of luck on converting the front 5 lug drums to anything else.
Your best bet is to have your wheel centers installed in new rims.
The wheels are a major reason why many shy away from these trucks. I have seen several F350s in nice condition at a good price, but didn't want to deal with these issues.
Old 09-27-2016, 09:59 AM
NumberDummy
All 1953/66 F350's (and P350 Parcel Delivery's) have 6 lug wheels on a 7.25" bolt circle.
William
12-22-2011 11:28 AM
Goatnut
06-16-2011 11:01 AM
L.TONY F350
04-17-2010 07:03 AM
wagonerkl
02-25-2010 08:05 PM
bobfl
Aftermarket Products
09-03-2002 09:47 PM
Quick Reply: 1964 f350 parts needed
