97 power window switch pic
Old Jun 30, 2016 | 07:06 AM
jwellsbmf's Avatar
jwellsbmf
Hello all
I have a 1997 f250 HD
While replacing the door pins the wires were pulled out of the combo power window / door lock switch . I cant seem to find a pic showing the exact placement of the wires. Does anyone have a pic of the back side of the switch showing where the r wires go?? Thanks
BTW its a reg cab
Old Jun 30, 2016 | 10:41 AM
rla2005's Avatar
rla2005
How about an actual diagram of the connector with the wire colors listed:
Pinout:
Wire colors:
Old Jun 30, 2016 | 01:07 PM
jwellsbmf's Avatar
jwellsbmf
Ok yes that would appear to be the one however i have an extra wire not listed its a red w/ yellow and it came from the door lock motor to the switch (has a terminal on end). Found a black with thin blue stripe too.
BTW the * without KE and ** with KE
Mine is with so would I not use (1) and (5) ?
thanks
Old Jun 30, 2016 | 03:38 PM
rla2005's Avatar
rla2005
I do not have any diagrams for trucks with Keyless Entry. They are all marked as Without Keyless Entry. I am not sure what the differences are.
You can perhaps use this as a reference:
As far the connector diagram is concerned I would interpret the pins with a single * are not used on trucks with keyless entry.
greaseball13
Electrical Systems/Wiring
Dec 17, 2018 03:40 PM
mdwilkins
Nov 4, 2017 10:32 PM
TAA
May 21, 2007 05:54 PM
tvvbsn
1997 - 2003 F150
13
Sep 27, 2004 09:40 AM
