Older ad clean up from the 48-56 forum. fomoko1
I have a 55 F600 I just don't have time to build. Only rust on it is the cab corners, otherwise a solid cab and front clip. Front bumper is busted but probably repairable. No engine, was a 239 Y-block. Trans is there and seems to be free moving/not locked up. $2500 best offer. Rust in the cab corners has gotten worse since the pics, still just a matter of cab corners though, hasn't migrated yet.
Hood Trim Needed - 1952 Ford F1 **HELP**
Hello, everyone- I'm looking for some trim pieces for my '52 F1... Original pieces were all accounted for & in pristine condition when I put in storage during my junior year of high school (had all the time in the world, but no $$). Fast forward 20 years, a little more $$ to budget, decided to get back into my project (although with work & Little Ones, free time is almost nil). I located the trims & pretty bits I'd set back, only to discover that something caustic had leaked on a few of them & they've virtually disintegrated... I mean, completely unsalvageable.
The trims I need to replace are the smaller stainless spear-shaped pieces (x4) that are located on each side of the hood, directly above and below the main/large spear. I have all of the other pieces, I just haven't been able to locate the ones I need by scouring my usual online resources (LMC, Sac Vin, Dennis Carpenter, Bob Drake, etc)
Any ideas or suggestions would be GREATLY appreciated!!
J Sanders, I've got the trim you need, I sent you an email.
I also have a Carburetor for a Flathead 226 single barrel. Model 7HT
top portion looks decent, the bottom portion (base with butterfly or throttle plate is rusty and the plate is rusted through)
Asking $20
Also have 2 different Aluminum Flathead 8ba timing covers Mercury / Ford timing covers. need a good cleaning.
asking $45 each
Also A Governor for a Flathead 8BA came off a running engine from old 52 ford dump trump, I removed it because I needed to go faster (ok, so not really haha) Anyway good condition just dirty on outside.
asking $15 or ? Model 8RC-18201-F
Range 2000-3500 rpm NL KS-V8S-251
52 5star extra trim
#30
Good to know! The parts book has two seperate part numbers for H and R series so I was not sure.
I have rebuilt one for my rebuild but I opened up a can of worms by changing the coils so I am moving to another one.
JB
JB
