97 f350 348,00 rough running help!!!!!!
Old 06-27-2016, 08:23 PM
Mgwilson86
Mgwilson86 is offline
Mgwilson86 is starting off with a positive reputation.
Im chasing my tail guys. Truck runs fine cold and at op temp for a while but then out of no where it looses power. Struggles to run and it idles rough. Let it cool down and all is well. When it acts up, it doesnt smoke. Doesnt throw any codes. Gauges look fine. Any ideas on what may cause this?
Old 06-27-2016, 08:39 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
knottyrope has a very good reputation on FTE.knottyrope has a very good reputation on FTE.knottyrope has a very good reputation on FTE.
Yank fuel filter and see if black.
If it is then new orings on injectors needed.
If not then check EBP sensor for blockage.
Maybe change CPS just so you know you have a good one. Use Motorcraft one as off brand Dont hold up well.
I just finished my injectors orings. Fun project.
Old 06-27-2016, 08:56 PM
Mgwilson86
Forgive the ignorance. What is the ebp sensor? I looked at the fuel fikter and it looked purple ish color. Im assuming due to the color of filter from previous owner
Old 06-27-2016, 09:07 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
Sounds more like an IPR ( injector pressure regulator) when they start going bad the coil heats up and does as you describe. Throw some water at it when it acts up if fixes it you have found your problem.
PS. The IPR is on the hpop (high pressure oil pump) on the bottom in front of the fuel bowl.
Old 06-27-2016, 09:14 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Could be just the IPR O rings. How does it start when its hot?
Old 06-27-2016, 10:36 PM
Mgwilson86
Well its hit and miss. At op temp sometimes it starts fine. Today it ran at an hour before just going to crap. The day it did it i was driving it for 2 hrs straight going to ft bragg. Drove fine and then boom, it did it for the first time. But once it does it, it wont restart and run properly until its cooled down some
John7894
11-28-2017 05:46 AM
Hey351
08-07-2017 12:53 AM
whitelx50
06-22-2017 01:03 PM
FiveOJester
2009 - 2014 F150
02-28-2017 06:20 PM
carcus
12-30-2016 06:32 PM
Quick Reply: 97 f350 348,00 rough running help!!!!!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
