What Transmission is in my '64 F-100?
Hey guys. I picked up my first Slick yesterday! As with any vehicle I buy, I immediately want to know absolutely everything about it! The previous owner wasnt too much help. He had too many vehicles to keep track of lol. Anyways, I have established that its a 223 ci inline 6. Mostly because (from what I can tell) it was the only 6 cylinder offered in a F100 in '64. The rear end appears to be a 9" (although the gear ratio is still questionable). This leaves the tranny. A search on the internet didnt help much. Its a 3 on the tree. The closest answer I could find is a T85? But its not definitive
The main reason I want to know is to find out what gear ratios this tranny has. 1st gear seems to be incredibly high. I have to slip the crap out of it to get going without killing it. Loading it on the trailer was quite a chore. I killed it twice, and Im a pretty good driver with a clutch.
Thanks for any info guys!
1964 could have the 223 I-6 (VIN engine code J) or the 262 I-6 (VIN engine code B).
The rear axle could be a 9 inch, if it doesn't have an inspection cover. If it does have a cover, it could be a Spicer/Dana 44 or 60.2 .. both with Limited Slip.
The 3 speed trans is probably the Ford type 3.03 3 syncromesh.
If the 3 speed has overdrive, it's the optional Warner T-86 (no 1st gear syncro). The optional Warner T-85N with overdrive was installed in 1965/71 F100's.
To verify, post the VIN .. the TRANS & AXLE codes, which are stamped on the 2nd line of the Warranty Plate, riveted to the left door below the latch.
MichiganLarry: The 3.03 3 speed was introduced at the beginning of the 1963 model run (September 1962).
The Ford 4 speed top loader was introduced mid-year 1963 (1963 1/2) along with the Falcon Sprint, 427 & Galaxie 500/500 XL Fastback.
I suspect the ratio the fine. I would look first at mechanical problems like dragging brakes, wheel bearings, clutch adjustment, worn clutch or a well oiled clutch disk. Just be be clear a clutch disk should not be "well oiled". Wear or contamination will cause it to slip.
Also it could simply be the new driver unfamiliar with how it drives.
The clutch isn't slipping. I have to slip the clutch in order to get the truck rolling from a dead stop without killing it
Ok here ya go. These are all the numbers from the door tag. Some are obvious but I'll post it all anyways lol
Warranty - F10JR567504
WB - 128
Color - A
Model -F100
Body E81
Trans - A
Axle - 12
GVW - 5000 heavy hauler... Lol
HP - 114
RPM - 3600
DSO - 71
WB - 128
Color - A
Model -F100
Body E81
Trans - A
Axle - 12
HP - 114
RPM - 3600
DSO - 71
J = 223 1V I-6.
R = San Jose CA Assembly Plant.
567504 = 1964, assembled July 1964.
128" Wheelbase.
A = Raven Black.
F100 2WD .. 5,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Check Stripe Woven Plastic / 81 = 81B Custom Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
I think I may have figured out what the issue is. It's one of two things:
#1 the truck wasn't drove much and the clutch needed broke in some. It shifts fine now
#2 I haven't drove a 3 on the tree more than once and Iv got the rythem of it
And of course both could be true. The trans seems to chatter less and take offs are better now that Iv drove the truck all day today
twin me beam
12-13-2014 09:14 AM
OKC_65_F100
19
07-06-2010 05:11 AM
swollenknuckle
04-13-2008 07:02 PM
