Jeff's 1949 Mercury M-68 (Ford F-3) Build Thread
It's begun. I bought this truck during the winter. Brought it into the shop in early spring. This week I got it cranking (it was not siezed) an ran a compression test. The numbers are not great but they could be worse. 115, 60, 80, 100 : 80, 110, 115, 70.
My plan is to restore the truck with a few modern upgrades for safety reasons. This forum has been a great resource for me so far and I'm hoping that this build thread will be helpful to someone in the future.
I have mechanical ability but I have never rebuild an engine before (I tore a few apart in the past thought). I also have no body work experience so this will be a learning experience for me.
I'll say thanks in advance for all the help and tips that I'm sure I will get. From what I have seen so far the people on this forum are great.
My current plan is a follows:
1) Get the engine running without a rebuild
2) Given that I succeed at point 1, then get it on safe rims, not widow makers, and take it for a slow drive and see how everything works.
From there I will decide how I want to proceed. Does my plan sound realistic?
Those compression #'s aren't that bad. You might try adding an ounce of SeaFoam to each cylinder, letting it sit overnight, then cranking with the plugs out. It is good for loosening stuck rings.
Have you changed the oil & filter? If so, how did they look?
Can you take a picture of where the oil lines to the filter are connected to the block, at the rear of the engine? It appears you have the Canadian full-flow system, a pic would confirm. That is a very desirable feature.
I will get a picture of the oil filter hookups to the block the next time I am there. My truck is 5 miles from home in my shop.
It's the equal of an F-3 which has a 6800 gvw rating. During that era the Canadians included the first two digits of the weight rating in their model numbers. The F-1 counterparts were F-47 and M-47. The F-2 model at 5700 lbs wasn't sold in Canada. The F-4 was the F/M-105, F-5 was the F/M-135. F-6 and above I don't recall. Stu
I noticed that as well but my guess is it's been in the body shop in the past . The Mercury name plate on the front is in very nice shape , thats good cause they are almost impossible to find .
