C-6 transmission tail shaft and slip yolk?
I am currently putting the pieces together for the drive shaft. I have a slip yolk that I'm not familiar with, it appears to be the correct one for my C-6 but I want to check with my experts here. This yolk is 8" from the center of the U cap to the end of the barrel. The appropriate yolk which is the 1310 31 spline is 7" from the center of cap to end of barrel and splined to the end. The one I have, the splines start about 2.5" from the end of the barrel and bottomed out I have about 2" from the seal to the yolk base. The output shaft protrudes a half inch past the seal. I am wondering if there will be enough spline engagement when I pull the slip yolk back about 3/4" to allow for slack. Or, should I trim about an inch off the un splined part of the barrel? I'll try and put some pics here. Thanks much, in advance.
Yolk is bottomed here.
Splines start at the right end mark, left mark is when the barrel hits bottom.
Scroll down to the 1330 and 1350 ujoint yokes on this page and it will give you specs on each yoke. Hope this will help you
Driveshaft and Driveline Parts > SLIP YOKES - For Automatic and Manual Transmission > Ford
The tag is missing but the transmission came out of a '77 ford econoline, it was rebuilt quite a few years ago. The engine is a 351w.
1975/77 E100/150 351W/C6 9" rear axle with 124" & 138" wheelbases.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
Pic: Here's the 4841 slip yoke specification chart. D7TZ-4841-A is the 13th entry.
Wiskey88
05-19-2018 06:56 PM
flamesoldier
13
11-18-2014 02:53 PM
ewturtle
01-09-2007 10:56 AM
Opiewan
09-17-2003 11:17 AM
