My wife just bought me a 2005 F350 DRW FX4 with a 6.0 in it and 100k miles for Father's Day. While I'm a bit familiar with the 7.3, I know nothing of the 6.0 except that it had a lot of problems initially. Any advice as to what to look out for or pre emptive fixes would be appreciated. Right now the only thing I can find that is an issue is the climate control selection for outputs i.e. Which vents doesn't work. Any and all advice or hints and tips would be appreciated. Truck is bone stock far as I can tell, and is running well at the moment. Thanks.
Vents defaulting to defrost can be a one of just a few things.
Leak or no vacuum or a bad blend door.
The vacuum pump is on the passenger side wheel well cover behind
the battery and vacuum reservoir. When you first turn the key to RUN
but not all the way to start you should hear (1) the injectors chatter
(2) fuel pump run and (3) the vacuum pump run. It also tends to be the
last one to finish. If you don't hear it then it worth looking into.
Boy, you have lots of reading to do here.
Start with changing your fuel filters, oil change, tranny fluid if not done at suggested intervals, etc. Use Motorcraft only.
Add a coolant filter, Blue Spring fuel regulator kit, and get something to measure your eot's vs ect's, etc.
Dig into the tech folder for some very good info.
A very good motor if you stay one step ahead.
So found the problem with the vents and it was the grey vacuum tube. Easy fix, thanks gents. I'll get back on any other items. And yes there is a lot of reading. Makes my night shifts pass faster and I enjoy everyone's posts and input. Learning a lot about my new rig.
Welcome to the forum Doc and as said before do some reading and evaluate the truck and see what you need to do. I agree from other people here, start by doing oil & fuel filters and coolant change and also tyranny too. Congrats on your new truck
Thanks ford diesel 06. Already in love with the rig. Had a 7.3 once but that was 20 years ago, still miss that rig. This one is an 05 F350 DRW FX4 with a 100k on the clock. As much as I can tell its bone stock except rancho shocks which I think may be shot. Had an issue with the vent selection but that's fixed now. Only other things I have noted are a steering wander right and left (may be the steering damper) and a suspension gallop when on concrete hi ways and that may just be the shocks. Also noted a whine when depressing the accelerator. I'm not sure about the whine but think it may be from the turbo. Never heard that noise before from a diesel. Any ideas or suggestions please let me know. My plans are to change all fluids and filters, the shocks and the steering damper and do a blue spring mod. Other than that, I'm adverse to changing things unless it's broken.
In general, I like that approach. The only thing on the 6.0 that I really hate is the EGR cooler. I waited until mine failed before I deleted it. If I had to do it all over again, I should have been preemptive on that.
New 6.0 owners are endlessly told "You gotta do this that blah blah blah to bulletproof it, spend $5K right away, blah blah blah..." And a LOT of times said "expert" has never even owned a 6.0. I've seen that for years on forums and in real life, and I'm sure others here have too.
From a long-term owner's perspective (I bought this new in March of '04), the truck does require diligence in maintenance schedules. I have had to work on it, but with the age and mileage (276K) things wear out. That said, I still have the original turbo, all original injectors, and head bolts. It's never been studded or otherwise "bulletproofed". When something does break, the truck does a good job of telling you what's wrong. And if you're even modestly handy with tools, you can do a lot of the repairs in your driveway. This forum and Youtube videos by DieselTechRon (may he RIP) are great resources when you need them.
I don't abuse it, but several times every week the turbo gets a little full-boost exercise. Nothing crazy, but I'll stand on that throttle. Use it, maintain it, and it'll work for you.
Welcome Doc! I will run a little counter to the crowd here, seeing as you have an '05 (which includes '05+), and suggest you proactively replace the Snap To Connect (STC) fitting off the HPOP. Ford tried a couple of fixes but came up with the final fix after the 6.0 had left the F series and was just in the Vans.
See many other parts of the high pressure oil system may very well let you know they are leaking internally, etc. But the STC, while it might warn you, also many times will not. If it separates you are dead on the spot. If it comes off and you are at high pressure, it can hit the rear cast aluminum engine cover and break it. Then you are both dead AND now you get to pull the trans or engine to replace that rear cover.
If you have or can get records see if it has already been done; otherwise I'd put it near the top of my list...
It can happen, just ask Per4mance....
Oh and on Edit: the FX4 package included Rancho 5000s....
I have an 05 SRW. It was all over the road when I first got it. For me it was just a matter of getting used to big truck steering vs small car.
Your getting some very good info here.
Deal with the things that need to be fixed first and if you happen
to have to go past something that is on the needs to be checked list
do that while you there if it has not been done. The STC can be a
bad thing and is well worth at least checking to see if it's been done
or not.
The one thing right off the bat that is well worth getting is something
to read live data like one of the ELM OBD2 port tools or the
SGII aka >>> ScanGaugeII : Linear Logic - Home of the ScanGauge
2 things that are not covered by the SGII EGT and Fuel pressure.
Some of the other systems have add-on that let you read x number
of added sensors.
Inundated with info. No, just kidding. This is great. All of you are really a big help and the info is truely priceless for any new owner. Keep the info coming. Awesome
I purchased my 05 in May and there were a few things I did right away after spending months reading and studying the 6.0. I've had a 96 OBS with the 7.3 and a 00 with the 7.3 so I was somewhat familiar with a diesel. First on the list was oil, fuel, ELC coolant and transmission fluids and filters. Then sent the FICM off to be gone through so I didn't have to worry about that. Next was the blue spring, tires, and ball joints. I had just bought a 140 amp alternator and batteries for the 00' so those got moved over. And finally checked the STC fitting and cleaned the turbo.
So after all that has been said and done I feel much better about my purchase and can drive it and not worry about it letting me down. Just read and get to know this engine and you'll be miles ahead of any problems.
And definitely get some sort of scan gauge it is essential in trouble shooting if a problem
arises.
