87 F150 won't crank
87 F150 won't crank
I have a 1987 Ford F-150 with the 5.0L engine. I had to replace the starter and battery and couple of weeks ago. Everything was fine until one morning this week I went out to go to work, turned the key and absolutely nothing. When I got home from work I put a new Solenoid on and still nothing...I jumped the solenoid and took it to a friend to look at it. After a couple of checks he determined it was the Neutral Safety Switch. He put a new one on and it cranked right up. I stopped at an auto parts place on my way home and when I went to start it to go home, it acted as if the battery was weak but it did start. The next morning I go to start it and all I get is a click when I turn the key to start it. I tried to jump it and that didn't help...any ideas on what could be going on? I'm a novice at best with engines and any help is greatly appreciated!
on
Jumping the two high amp lugs really should never be done!
I know lots do it, it only takes once to regret it!
- One screw driver will not make contact with both lugs, So what do people grab that will ... Two screwdrivers, a pair of pliers, a small piece of wire.
- What if they use something that cannot handle the amps ... It'll melt in their hands!
- What if they have been working on the fuel system and have a little gas spilled about ... Sparks and Boom!
- Not to mention melting the lugs and whatever is used to jump them.
-Enjoy
fh : )_~
Jakedog1996
07-23-2014 05:59 PM
92 Red F150
08-12-2010 12:17 AM
