22.5 Budd's vs. the old odometer
So who wins what works what changes and what happens because i don't have a clue. Will everything just turn faster and accurately keep track of my miles and current speed or will all readings be totally off? Originally the truck had 20" Firestone RH-5 widow makers that had to go and were about 34" tall and my current setup is 38.3" tall.
As you can see there is a little more tread on the new tires
Samson GL274A A/P 9-22.5 Radial 14 PLY
My whole garage still smells of new tires
Well I was hoping to do 55mph without the engine screaming. I went with clip on wheel weights because I didn't want that magnetic powder garbage. Before I couldn't roll my old tires 2 feet without them falling over, now my new ones roll with ease not toppling over. I noticed a big difference.
Apparently the old tires that were 7.50-20 front and 8.25-20 rear are too small? As previously stated the old rims were 20" Firestone RH-5 rated for 7.50" wide tires or 8.25" I'm not sure but the 8.25"s were probably rubbing on the back dually setup with a load? Before i could barely get one finger in between them. Now with 7.50" inch tires I get two fingers with plenty of room. Maybe I should pull out a tape measure and measure something. ha
Wee... were going for a ride!!!
or so they thought.
Good thing I never aired them up, i wouldn't be here right now
or so they thought.
Correct, the standard F-6 was equipped with seven 20" x 6" wheels fitted with six 7.50" x 20" tires (8 ply rated). No spare tire on the wheel. Optional extra cost were two 7.50" x 20" (8 ply rated) on front with either four 7.50" x 20" (10 ply rated) or four 8.25" x 20" (10 ply rated) on the rear. Highest option was 8.25" x 20" (10 ply) on all six wheels.
If your tires measured 34" it can only be explained by years of deterioration or maybe under inflation. Or you measured wrong. Stu
Yeah some were retreads, all were worn and none had more than 8 or 12 psi. I had a big chain threw them and around a double tree when i let them loose (should have took some pictures) we unscrewed the schrader valves and then i cut them up with the sawzall. So in the end nothing spectacular happened it was more like one of those moments where your so focused on not having anything go wrong, that we were out there standing behind the tree in case one let loose so we didn't have time to think oh let's take some pictures and enjoy the crazy moment!
This is probably the best picture I have showing the space between the tire and fenders. I never thought to measure the gap as I did not originally intend to change the rims out or go with bigger tires (which in this case wound up being closer to the correct size). Given the new information and by the looks of this picture my new tires with all their tread should fit hopefully. I hope
F-350PSD
03-22-2008 10:12 PM
