For those with the 50 gallon Titan tank!
#31
My truck is supposedly programmed for a 50 gallon tank and it seems to be other than the most I have put in it when it's showing close to empty is 38 gallons. I have yet to run it long enough to have the low fuel light come on! How accurate are you guys seeing with your setup on the gauge and distance to empty?
#32
I do not watch the fuel gauge as much as the trip meter. I reset the trip meter each fuel stop and check the fuel quantity used. I know my 65 gallon tank uses 10 gallons before it comes off 100% fuel level on my CTS2. Once it starts to move, it is in concert with the factory gauge verses the CTS2.
#33
When I had the dealer reprogram mine in Fort Worth the shop foreman came and asked me if I wanted to select 45gal or 55gal for the reprogram as 50 isn't a option on their software. Wanting to err on the side of too much fuel left vs not enough I chose the 45gal setting. The miles till empty might be off a bit but fuel used on the trip meter is always within .5gal used when refilling at the pump.
#34
When I installed mine, I put 4 gallons in it then drove two miles to the station and filled it up. I almost always fill it at 1/4 left and almost always put around 40 gallons in it. The trip meter is higher by 1/2 to 1 gallon used. I don't like anyone putting fuel in my truck so sometimes I might fill it up at a half tank just so the wifey doesn't have to fuel it up if she needs the truck for something. This was a great upgrade to the truck. It is nice not to have to fill the truck up before every trip.
savage250
6.7L Power Stroke Diesel
06-27-2013 10:56 AM
