Rear Bench seat dimensions
Hi all,
New to the site but not to Fords. Quick question that I can't seem to find anywhere. What are the dimensions of the rear bench seats in a 1994 F150 extended cab. More looking for the bottom seat cushion measurement to see if a car seat will legally fit on it before I purchase one. Seat back cushion measurments would be great too. I am looking at an F150 with jump seats that need to be swapped. Thanks!!
A CREW cab would be close to using a car seat, but a SUPERCAB or extended cab has a cushion about 2/3 that depth. With a full size seat, you would have no leg room. Years ago I made a 2 x 8 box frame and put a padded piece of plywood on top for a seat.. hing forward and had tool box in the the 2 x 8 frame.
99 03 F 150 Supercab Tan Cloth Bench Backseat Upper Bottom Top Cushions Nice | eBay
well I have a 4 door CREW cab and the backseat is about the same size as the front.. full bench.... Now a SUPERCAB is much shorter behind the front seat.. That's why you have two jump seats, to get the leg room. If you measure from the rear cab wall to the back of the front seat, I don't think you can get a regular bench in there. If you do, I doubt there will be 3-4 inches between the front and back seats.
patrickke
1999 to 2016 Super Duty
12-16-2009 02:32 PM
