1997 f250 hd running ruff all at once
Old 06-19-2016, 11:15 AM
Keithf1's Avatar
Keithf1
Keithf1 is offline
Originally Posted by fordpride
Ohm them from the outside of the valve cover
Put ohm meter on from outside of valve cover everything seems to be right any other ideas?
Old 06-19-2016, 01:38 PM
farmert's Avatar
farmert
farmert is offline
Check the main wiring harness where it runs over the drivers side valve cover. You will probably have to remove the loom to inspect the wires. The wires have been reported to rub threw were they lay an the valve cover.
Old 07-18-2016, 02:27 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
Any updates for this thread?? My buddy is having a similar problem with his 96. He's going home tonight to pull valve cover and inspect the harness. Curious to see what the problem ended up being for Keithf1
BieselDiesel
30
06-11-2019 10:00 PM
lowcan
08-05-2009 05:14 AM
Kizziah
08-05-2008 12:37 AM
lwhitcomb
09-25-2004 09:22 PM
bbarr
12-26-2003 03:19 AM
Quick Reply: 1997 f250 hd running ruff all at once
