5.8 help — delete smog, AC, and PS
Do you know the year E4OD you've got? It will have some relevance on what ECU & wiring you use.
The alternator bracket can have the air pump portion cut off & it has space for an idler & the tensioner. You don't even have to use the PS/AC bracket. Just a question of measuring out for a belt. You'll have to keep the rotation the same on the water pump. It wouldn't look bad.
Adapting a column shift in an antique, that'll take some fab.
You got any current pics of the recipient's current state?
EGR is a separate system from smog and cannot be deleted without setting codes, but the whole air injection system can be removed no problem and it including the air pump and all associated hoses and valves, just make sure the holes in the back of the heads(f150 motor) or the exhaust manifolds(F250 motor) are plugged and the TAB/TAD solenoid/s near the coil remain electrically connected. If you are installing headers you can disable EGR by leaving the tube off and plugging the hole in the intake so no fresh air gets in but the valve must remain in place with both the electrical and vacuum attached to keep the computer happy. Alternatively adding a bung to the header isn't that hard and functioning EGR does improve gas milage slightly and reduces the engines sensitivity to detonation.
A) i am using headers. where to get bung (and which bung)?
B) best way to plug the holes in the back of the heads?
C) which "tube" is left off from where?
thanks.
i see in your sig you're also running the E4OD. this thing is *huge*, but looks like i will be able to shoehorn it in this ol' '52 with some floor mods.
(just finished my custom fab'd mount for it today!)
on
Thanks!
Scott
This item...
Is connected to the "bung" on the header I showed by this pipe (Which you should still have if you didn't break it)
It is operated by the front solenoid shown here:
Behind it are the 2 solenoids that Conaski mentioned that you need to leave connected to the wiring harness in order to not set codes after deleting the air pump & related plumbing(Thermactor system)
Thanks.
#28
#29
Well, yeah, you could leave that big ole ugly hunk hanging off the side of the the intake & come up with some sort of cap that probably won't seal too well & possibly cause a vacuum leak.
As far as plugs for the heads, a couple of 5/8ths x 11 tpi (coarse thread) bolts an inch long will screw right in after cleaning some of the carbon out of the threads. Some put a copper washer under the bolt head. I just slathered them with anti-seize.
#30
Excellent, thanks for the tip!
