1960 F100 Rear Bumper Brackets
hi Wild78,
i read the the thread and am still confused as to what brackets you used (with modifications). Can you let me know? I have the same bumper as you.
The brackets I ordered say 48-72 stepside.
will those work if what you said above is true that they are the same?
thanks!
thanks!
I would say no, the brackets are flat. It might pull back out when you tighten it down hard to say. That center section likes to kink if you bend it to much! If you have a long enough piece of I beam you can use big clamps and blocks of wood to move it where you want it or is this something you will return?
d
asmith6
04-20-2017 10:31 PM
billslk32
01-15-2012 01:01 PM
