F100 Panel Truck Question
Old 06-12-2016, 02:50 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
I was at a local show today and was looking at a 55 panel truck. A discussion about the differences between the 53-55 and the 56 panel trucks got started. The owner of the 55 said that the roof on the 56 was different than those on the 53-55. There was also some debate on whether the rear doors were the same across the years. Can anyone clarify?
Old 06-12-2016, 08:14 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
I'm pretty sure the barn doors are the same. i only have a 56 Panel so I can't compare roofs to see if there is a difference.
Old 06-12-2016, 08:17 AM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
bigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant future
Rear doors are the same but the roofs are different
Old 06-12-2016, 08:18 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1956 pickup (all conventional cabs) roof is different than 1953/55, due to the wrap around windshield, so I would assume that the panel roof is different, too.
The rear doors should be exactly the same, 1953/56.
Old 06-12-2016, 01:50 PM
CharlieLed's Avatar
CharlieLed
Thanks Kevin/Bill/BJ. Some time ago I was going to make a mold and layup some one-piece doors for the F100 panel. The guy I was talking to yesterday has a panel that he would let me use to make the mold. I haven't looked the panel over real well yet but he is stopping by my place later this week so I will check it out then.
Old 06-12-2016, 04:33 PM
56panelford's Avatar
56panelford
56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
The roofs are about an inch and a half higher on the panels too compared to the pickups. Making fiberglass hatch still door would be a big plus because the 2 steel doors welded together are quite heavy plus it is hard to find good rust free doors and would be a shame to weld them up if you did find any..Some like them to look as two individual doors with the 2 separate windows while others like them with the single one piece glass.
Old 06-12-2016, 05:49 PM
CharlieLed's Avatar
CharlieLed
John, I remember having this discussion some time ago. The door(s) on your truck looks great. Is that a fiberglass door? Did you fabricate it? I am thinking about using a sliding mechanism, similar to the side door on a mini-van, that will allow the one-piece door to swing out and then push in to disappear into the underside of the roof. Kinda like the cover on a roll top desk or better yet a garage door.
Old 06-12-2016, 06:08 PM
56panelford
Posting Legend
I welded the 2 doors for mine Charlie, the reason I say they are heavy. I have a single door popper in the center of the door but it's not strong enough to pop the door open on the second stage of the bearclaw and I have to grip the bottom of the door and lift as I activate the actuator. I did cut out a fair amount of the inside of the doors to lighten it but still not enough. I think a glass door would be the ticket..
Old 06-12-2016, 06:13 PM
56panelford
Posting Legend
Not a full on view in this picture but think there is enough to see how much I cut out, I'm thinking of removing some of that Eastwood acoustic shield to see if that will lighten it some..
Old 06-12-2016, 07:08 PM
bjmayberry2
Charle,
Wish you lived closer, I have a pair I could loan you. I'd try to mold some myself but have no experience with fiberglass. I want a hatchback but hate to bugger up decent metal doors that someone else could use.
Old 06-12-2016, 07:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
I'm not sure a glass door would be that much less weight after you add in enough structural ribs to prevent warping, to get a good seal, and provide strength at the hinges and lift points. The window glass is heavy too.
Old 06-12-2016, 07:39 PM
56panelford
Posting Legend
I have no idea what the difference in weight they would be, should have weighed this door in case this subject ever came up I suppose. I know I'd hate to be under it if the gas shocks ever failed or even worse if my wife was under it...
Old 06-12-2016, 08:21 PM
CharlieLed's Avatar
CharlieLed
There are many structural foams on the market today that provide exceptional strength without much weight. Some of the stronger ones are even machinable. My thoughts would be to build a door that resembled a surf board...strong foam core with a lightweight carbon fiber skin. A side benefit would be exceptional heat and noise isolation. When my buddy comes by this week with his panel I will assess the condition of his doors and go from there. Thanks for the offer BJ, the internet has made the world smaller but until someone develops a Star Trek transporter we are still miles apart.
Old 06-12-2016, 08:24 PM
bjmayberry2
Charlie,
If you build em I'd like one if the price isn't too high.
Old 06-12-2016, 08:25 PM
56panelford
Posting Legend
Do you have any ideas as to what these doors might cost Charlie, sounds like it would be a lot of work to make the molds.
Quick Reply: F100 Panel Truck Question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
