97 7.3 stalling issue
My 97 7.3 just started having a stalling issue it has a brand new triple disc Tourque converter the truck runs find for about 30 mins then every time I slow down for red light rpm drops and truck stalls it will start right back up . I thought it was bad converter so they
Sent another new one and It didn't do it for about 3,000 miles now it is doing it again. Any help would really be appreciated thank you
Do u have a torque converter lock up switch installed?
He makes a good point. If you've upgraded your tranny cooler to something bigger than the carton of cigarettes sized stock tranny cooler. Then u need to add tranny fluid. The larger tranny coolers can take up 1 quart of fluid once ur pump starts pushing into it. So even if your dipstick reads full while sitting, its gonna be at least a quart low once it starts filling the tranny cooler. Get it hot and moving then check it while its running in neutral with the parking brake on. My tranny fluid level while sitting is way above all the hash marks. Then drops down to the H hashs while its running and Hot.
No I do not have a lock up switch installe
Scaper
21
12-16-2011 09:36 PM
