5th Wheel Under 30' with 2 Slides
  #31
Old 06-23-2016, 07:00 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
I was curious if you fifth wheel actually measured less then 30 feet pin to back bumper of fiver. Mine measures 29' 8" and yours looks much longer than mine in the picture. Not an issue, just curious as I found when I was running around measuring that some were exactly what the manufacturer listed and some were a good bit more than the stated length.
Steve
  #32
Old 06-23-2016, 08:04 AM
jackfordsd350's Avatar
jackfordsd350
jackfordsd350 is offline
jackfordsd350 has a good reputation on FTE.jackfordsd350 has a good reputation on FTE.jackfordsd350 has a good reputation on FTE.
Steve
The Crusader is right around 30 ft. It is a 26 RLD which seems to mean 26 foot behind the truck 4 feet over truck. It has a 8000 dry weight and 10000 pound gross weight. I wish it had about 2 more foot in the back behind the slide. What 5th wheel do you have? I think my camper is still in production.
  #33
Old 06-25-2016, 07:37 PM
T diesel's Avatar
T diesel
T diesel is online now
T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.
  #34
Old 06-25-2016, 09:19 PM
Irish19614x4's Avatar
Irish19614x4
Irish19614x4 is offline
Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.
Originally Posted by T diesel View Post
How are the newer Forest River units? Those fifth wheels look nice and accomadating at least for maybe two people. They are also very light these days does that mean they skimp on quality or is it well made structural wise and all?
Times have changed so I know they can use different materials.
  #35
Old 06-26-2016, 07:21 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Short fivers from any manufacturer are not I would call "good quality" in terms of construction including my own. By way of clarity, I do not mean they can not be enjoyed. What I mean is the basic box is no more than average and may be subject to more problems than higher end fivers. For example, water damage and delamination are more probable, in my experience. You will also find basic box construction may be less impressive, etc. I wanted to clarify my comment as I do not want to sound insulting. It is simply the case there are real differences.
The demand of short fivers of any brand is really impressive. We just sold the shorter of our two fifth wheels yesterday. After putting it on Craigslist for one day, the first folks who came to see it paid cash for it after I asked them to sleep on it overnight. In the mean time, we have four folks offering us more than we were asking if we would sell it to them instead and we sold it for $500 over book retail. Crazy world.
Steve
  #36
Old 06-26-2016, 08:31 AM
T diesel's Avatar
T diesel
I think you'll be pleasantly surprised.
  #37
Old 06-26-2016, 09:08 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
If the surprise to make your day includes roofs that can no longer be walked on, wall joist 24"-30" apart, and press board floors, along with more plastic and vinyl wraps, you will be impressed.
Sight down the side of some of the ultra lites and see how flat the wall is on the exterior. Just lots of corner cutting everywhere.
Just my two cents,
Steve
  #38
Old 06-26-2016, 10:48 AM
T diesel's Avatar
T diesel
My 2011 has been flawless.
  #39
Old 06-26-2016, 12:06 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Being flawless and build quality are not always correlated. In my experience, build quality is based on materials and manufacturing. You have to get lucky at any level, but there are some flaws that, when they occur, you see them far more often in less expensive models.
For example, slide seal installation and type vary greatly based on cost, single wiper versus double, etc. and leakers are more common in less expensive models, although they can occur across models. Wall construction that is not entirely straight is more common in less expensive models. There simply is no upside to having a roof you can't walk on or a floor that is press board rather than 5/8" OSB when it comes to longevity.
As you know, I am consistently negative about construction quality in the RV industry and even more so on my blog. I simply see too many things that should never be and I see them more in ultra-lite models. In that regards I admit to a clear bias against the new light weight models.
Steve
  #40
Old 06-27-2016, 07:27 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Originally Posted by jackfordsd350 View Post
Good eye. I added the Correct Track system for two inches of lift.
I haven't installed the Correct Track yet, but ordered it and should have it in a couple of days. I read over the installation instructions and watched the video. Did you do anything that was not in the instructions you found to be helpful?
Thanks,
Steve
  #41
Old 06-27-2016, 10:41 AM
jackfordsd350
Thanks,
Steve
Just followed directions. Make sure you sort the bolts. Check my picture and how the bolt length should look. I had to swap a couple of bolts to get things right. You will like the kit and the two inch lift.
  #42
Old 06-27-2016, 10:59 AM
Irish19614x4
Steve
Well I didn't mean to turn this into a debate, value your experience and expertise Steve. It does appear that your knowledgeable about RVs and been around them for quite sometime.
It's a shame companies are still cutting corners but it comes down to costs for them to make them what we feel is affordable but really we are you putting the money back into there grimy hands.
Most people will have the RV serviced at a shop and pay out the *** to do so and might only keep the unit four to five years then sell it. Perhaps buy another one and so forth. People like us who buy one use it for much longer than above years and end up finding all the cut corners on them and fixing them right.
  #43
Old 06-27-2016, 11:01 AM
Irish19614x4
I know mines not 30' or less but even for a 16 year old unit I was pleasantly surprised Nada guides values mine at $10,500 and I got it for $6500. Sure I had some issues might still have more but I believe itd a quality rig.
  #44
Old 06-27-2016, 11:27 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
I didn't mean to debate either. This whole quality thing is a real hot button issue for me because I feel like so many people just get trashed and it pees me off majorly. I really like RVing, but some of the stuff I see is simply inexcusable. If folks are told and still want to buy something, it is on them, but when they get blind sided, it just really frosts me.
Steve
  #45
Old 06-27-2016, 11:38 AM
Irish19614x4
Steve
Agreed 100% with above....it makes me mad watching folks get screwed on vehicles and maintenance of them as well. Since I do all my own mechanical work I save so much and well I enjoy doing it so I learn a lot.
I hate it when my friends or family come to me and say yes I got this done over the weekend it was $250 when the parts maybe cost $50. Sure it's labor etc but it drives me insane. Wishing more and more people would do research and attempt to not be scared to work on their cars. They will find out how much money they can save.
Then you just have those who have money and no time so they say so they don't care about pissing away their money.
Quick Reply: 5th Wheel Under 30' with 2 Slides
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
