My truck won't start sometimes and after sitting there for 30 minutes or 2 to 3 hrs,it will start again.When I turn the key all the lights are on but it does nothing.I replaced the battery(free) and they tested (advance auto part) the alternator and starter was good.I put it in neutral and it won't start either.Like I said after couple hrs.Should I change battery cables? ty
It happens both ,hot and cold.mostly in the morning or I go store and come back to start (after a few minutes) and won't start.After starting,it will run and start again and again for a while till I need the truck the most and it won't.lol
It is original but I did take it down and took it for test to advance place when the truck wouldn't start at all they said starter was fine,the problem was N-safty cable.That was one one half year ago.
When doesn't want to start,no crank at at all just the lights are no sound.The engine does not crank.after sitting for a while yes it starts like a champ.
Come to think of it ,it could be an electrical issue (I was going to mention).Everytime the engine does not start as soon as I turn the key inside the truck starts to play electric drums.
So the clicking noises are normal(when I try start).I have to take my mother for radiation,I will check the wires in couple of days.I hope it starts for next 2 days.tyvm for ur helps
