Vacuum Leaks Thermactor and EGR CODE
Truck is a 1991 302 bronco, Title says it all,truck runs semi rough, have been driving like it is for the past 600 miles since I bought it but have now started working on a lot of stuff. Just replaced timing cover and chain. Now I replaced egr and sensor because of CEL and still no help same codes I believe 332 and 317. all I remember is thermactor not engaging and EGR Something. Well there is a loud whistle from under hood. Also there was a yellow vacuum line behind the upper manifold/plenum that I believe is to the TAD that is unhooked I tried going behind there with my hand and plugging it in and snapped the line. So my question is where does the line end plug in to?? I can find where it comes from on the right side but can not find where it plugs into the rear of the intake manifold.
I have an 88 Bronco XLT 351w and I just replaced all my vaccum lines with rubber hose it is running a lot better. The light brown, beige goes to a valve on the left side below spark plug level and the nipple was on the bottom of the valve. I found it easier to get on the driveway and attach it from underneath. At least that is what I found on mine.
dleavitt
17
09-13-2016 08:04 AM
Gnnut
1983 - 2012 Ranger & B-Series
21
07-18-2012 09:24 PM
whateg01
08-27-2007 09:48 AM
compaddict
07-21-2005 08:43 PM
