12V switched power/secret wire bundle?
In my 99 it is lt blu/pnk just to the right of the steering column. Has a tag on it "Customer Access". Just a single wire.
There is also a group of 4 wires tagged together. These run through the firewall and can be found inside the cab, and the other end under the hood near the brake booster. Also tagged Customer Access on both ends of the group. They are for accessory circuits into the engine compartment without having to fish wires through the firewall.
Here it is.
Took me a while but found it in the end. Plus some pre run wires that go through the firewall for customer use:
https://www.ford-trucks.com/forums/1...tched-12v.html
