S10 Transmission in a M68 Truck?
Old 06-03-2016, 05:52 PM
dcavan001's Avatar
dcavan001
dcavan001 is offline
The project is well underway with our 1949 M68 Mercury pickup, and I'm going back and forth on a transmission choice. I can save a few $ by going with a S10 five-speed, but occasionally I read that this might not hold up on this truck, which is rated as either a 3/4 ton or a 1 ton depending on who you talk to. Any thoughts on that S10 choice?
Old 06-03-2016, 06:26 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
What engine? What rear gears? Planning on towing or hauling loads?
Old 06-03-2016, 06:31 PM
dcavan001's Avatar
dcavan001
255 flathead, planning on something like 3.73 gears (working on gearing ratio that gets us a decent 55 or 60 mph on highway). No loads - maybe some groceries on Sunday afternoon, that kind of thing.
Old 06-03-2016, 07:00 PM
mOROTBREATH's Avatar
mOROTBREATH
mOROTBREATH is offline
Most important things you should consider when using a non-factory matched transmission is 1) how much torque will your engine produce, and 2) how will you use the vehicle.
A 255 flatty is not going to produce enough torque to destroy that trans in one day, but over time it could, but I guess anything could.
And this brings us to the next point: You'll only use the truck as a cruiser, no real truck loads to speak of.
That trans should easily do the job for a long time as long as you don't haul considerable amounts, and go easy on it. No clutch dropping.
If you need to haul you should be fine, just go easy on the girl and don't shift into the 5th OD gear.
Old 06-03-2016, 07:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
You probably want to stick to World Class T5's and keep gearing around 4:1 so 5th isn't useless.
Old 06-03-2016, 09:24 PM
dcavan001's Avatar
dcavan001
Thanks mOROTBREATH - that's been my thinking as well but you know how it goes - you never know until you try. Builders around here tell me it will work as long as I don't overload it, which is definitely not the plan.
Old 06-03-2016, 09:26 PM
dcavan001's Avatar
dcavan001
ALBUQf1 - that's definitely the other option I've been going back and forth on. It would give me a more robust solution for sure. Appreciate the insight.
Old 06-04-2016, 02:24 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
You could also consider the top loaded, top shifted four speed from a early 80s F-150. Fourth gear on these is overdrive. This is not a heavy duty transmission, but neither is the T5.
Old 06-04-2016, 02:39 PM
49f3dls's Avatar
49f3dls
49f3dls is offline
There are two types of T5. You want the world class (I believe that is what it is called) T5 if you go that route. It is a heavier duty trans and will hold up even if you haul moderate loads. Have fun
Old 06-04-2016, 08:27 PM
dcavan001's Avatar
dcavan001
Thanks everyone for the advice. I'm going to continue to check the options - the T-5 is readily available as is the S10. I haven't actually consider the 4-speed '80's F-150 transmission, but I'll check around for that as well.
Old 06-04-2016, 08:34 PM
dcavan001's Avatar
dcavan001
49f3lds - it is indeed the "world class", and if I end up going with a T-5 that's the option I will choose based on its rep for being a bigger tougher device
SNOWR8R
17
07-16-2019 10:00 PM
jdphillips73
02-24-2008 09:08 PM
chimchim
1997 - 2003 F150
24
07-27-2007 06:32 PM
Jefe
05-17-2006 03:59 AM
5.4owner
Modular V8 (4.6L, 5.4L)
10-18-2003 11:48 PM
Quick Reply: S10 Transmission in a M68 Truck?
