What did you do to your Super Duty today? - Page 69 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #1021
Old 01-29-2018, 05:57 PM
geekwithoutacause
geekwithoutacause is offline
geekwithoutacause is starting off with a positive reputation.
It's amazing how Ford still has issues with manifolds. It looks like the newer explorer models also have broken exhaust manifolds resulting in CO getting into the cabin. sigh
  #1022
Old 01-29-2018, 06:40 PM
Mastertinner
Mastertinner is offline
Mastertinner is gaining momentum as a positive member of FTE.
I know. WTF. I was just talking to a guy this weekend and his sons 5.0 coyote motor has the dreaded ford modular motor exhaust leak tick. You would think after two decades they could figure this out.
  #1023
Old 01-29-2018, 06:42 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Ron94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to all
Originally Posted by Sdowdle541
Iíve followed your truck for awhile so you may of had some persuasion. Got lucky on this truck and the driveshaft doesnít interfere with the exhaust at all.
Glad I could help you spend your money! Good deal on the drive shaft.
  #1024
Old 01-29-2018, 07:32 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Brought home my f350 with it's plow installed. Now I need to lift the front end, the 4400 FAGW front springs are going to get upgraded, just not sure to what - yet.
meyer 7.5 lot pro with wings
  #1025
Old 01-29-2018, 11:22 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
i]
I highly suggest X-code (plow prep) springs from ATS or if you can find some on a truck being parted out. I've run them on two Excursions and loved them.
I signed the papers on my new to me 04. This is gonna be a quick flip. Picking up a tailgate, going to refinish or replace the running boards. New windshield, detail it up real good and send her on to the new owner. Selling the camper by itself.
  #1026
Old 01-30-2018, 01:11 AM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Russ,
Yes, am talking to Junior already.
I want some lift as well to ensure hitch mount stops hitting things from being too low.
Order with Junior placed, can't wait to get the full kit.
Will start a thread once the box arrives...
(My excursion is getting pi$$ed at me, got to move it in to the barn this weekend)
  #1027
Old 01-30-2018, 09:27 PM
EDC8008
EDC8008 is offline
EDC8008 has a good reputation on FTE.EDC8008 has a good reputation on FTE.
Replaced my idler pulleys, belt tensioner assembly and serpentine belt today at 116K miles on my 6.7 diesel.
Had a belt squeal develop about 2 weeks ago when it was cold. Got the parts today and replaced them. A couple of lessons learned;
1. There are 2 idlers plus the tensioner. Dual alternator trucks have grooved pulleys for the idlers and single alternator trucks have grooveless. All of the diesels use the sane tensioner and it has a grooveless pulley.
2.
They fail to say in many of the instructions that you must remove the bolt for the fan clutch mount and disconnect the wire. If you don't d this you can't remove the old belt or install the new one.
3.
There is also limited space to get into the bolts for the pulleys but the top of the fan shroud can be removed as it is held by 5 bolts and this gives a tremendous amount of access through the fan
Took about 2 hours to get it apart as I had to go back and pull the shroud off, but reassembly only took about an hour and that included pulling tools back out.
  #1028
Old 01-31-2018, 10:57 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Finally got the ids hooked up to my truck and disabled the hyper flash I was getting because of the LED bulbs.
I also got around to fixing my left rear door. I put aftermarket keyless entry on almost 2 years ago, and a few months back that door quit working. Then the lock got jammed unlocked. Turns out a set screw loosened up that connects the actuator rod to the lock rod and a wire had broke at a butt connector.
  #1029
Old 02-01-2018, 03:11 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
ram air hood
ordered the ram air hood
will be painted and clear coat to match truck
shop is local so I will pick up
takes air in the front and vents it over the turbos and near the cabin intake.
didnt want the one that vents to the air box.
should be ready in 5 weeks.
  #1030
Old 02-01-2018, 07:16 PM
I-Toon's Avatar
I-Toon
I-Toon is offline
I-Toon is starting off with a positive reputation.
Thumbs up
Nice hood! Congrats!
  #1031
Old 02-03-2018, 01:39 PM
devans04250
devans04250 is offline
devans04250 is starting off with a positive reputation.
I got a little too close to a pile of snow in a parking lot and ripped off my passenger side running board. I'm trying to figure out a good way to reattach it until I find a replacement.
  #1032
Old 02-03-2018, 08:55 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
pulled the transmission last night after work. Finished installing a Transgo Tugger kit as well as Transgo lock up valve, Sonnax line pressure modulator and O/D clutches. Transmission shifts great now. Also gave the thing a much needed bath.
  #1033
Old 02-05-2018, 11:30 AM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Brought it home
The F250 has been stored down in town for the last 8-10 months waiting for room to work on it.
Saturday we towed it up to our place, still waiting to clear a few things (my tools from FL) out of the way in the barn to pull BOTH the F250 and Excursion inside to start the suspension swap.
Ot got dirty being towed up in the mud
The 2 meet for the first time, the Excursion getting a 4wd transplant thanks to the F250. I plan to spend some time tinkering on the non-running 6L in the F250 to get some experience without risking the 6L in the Ex.
  #1034
Old 02-05-2018, 08:53 PM
Mastertinner
Washed the salt off the truck and gave her a coat of collinite wax #845. I normally use meguiars products, but heard good things about collinite.
  #1035
Old 02-05-2018, 10:04 PM
super 6.8
super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
Went ahead and had the dealer do a cooling system flush. I've been putting it off and it's too cold here to mess with it. While at the dealer I had the power steering fluid flushed too.
Prior to the trip to the dealer I gave it a good detailing.
Kinda funny but they gave me a 2018 F150 STX for a loaner. I took it back after work and when driving my truck home I realized I wouldn't trade them straight across for the new one.
Quick Reply: What did you do to your Super Duty today?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
