What did you do to your Super Duty today?
#887
#888
That type of front receiver is not going to hold the weight......you need the one that had the H frame attached to the recover so that it does not tip and hit the concrete on bumps if loaded Harvey on one side....ask me how I know.
2 things you can do
put large milk crates inside to separate the load and prevent it from shifting
bokt on some hook rings on the bottoms of each corner on the truck side and hook chain the hook rings to you tow rings .
2 things you can do
#890
#891
Been working on my project for some time now. Next year I'm getting a truck camper slide in type and had seen several different setups that guys had with toolboxes attached to a front frame hitch because they had campers in the back. The first thing EVERYONE is concerned about is airflow, but everyone that has done it so far has had no issues with it, and if you look closely at my setup you will notice that it's low enough to allow airflow through the radiator anyway.
Front view with safety poles off of snow plow blade. used a harbor freight cargo carrier as a base. Had to cut some of the top railing on so I could fasten my Craig's list $80 truck box to it.
had to make cuts at blue lines so base could be fastened to tool box
Had to buy the frame mount hitch receiver from Amazon, that cost $105. That required removal of front end bumper assembly, some hole locating and drilling and blind bolt fastening. took me a few hours, but I'm fat and slow... also had a friend weld on another receiver to lower it 6". here you can visualize the attachment and the extra receiver mount that was lowered
another close up view of front end. two padlocks on latch hasps and safety cable with combo brass lock ties to frame with receiver pin lock as well for security 4 locks in all. can't open top with steel cable locked up, if you could manage it, then you'd have to also cut the other two master locks which now are actually brass industrial not pictured here. And if you thought you could simply remove the whole assembly there is the matter of the receiver pin lock.
#892
My biggest concern would be the fact that those hitch haul carriers aren't designed to carry that kind of weight. I could just see touling along at 65 mph, hitting a rough bridge expansion joint and the next thing you know your doing the dukes of hazard jump off your now in the road tool box. Just my .02.
#894
additional receiver welded to bottom to lower tube receiver
2 things you can do
2 things you can do
#896
I installed emergency strobe lights in my truck (I'm a volunteer firefighter) awhile ago, and the grille lights were ziptied to the honeycomb grille till today, when I fabricated brackets from some scrap aluminium I had kicking around.
When I initially installed the lights, I cut out part of the honeycomb so they would sit flush, and the rear of the light would be recessed into the grille.
Out back, I have a strobe light in each taillight and reverse light, and they are set up to alternate (drivers tail and passenger reverse flash at same time, and vice versa)
#897
#898
on
Blue is PD only here in AR. Big messy felony stop if you don't have some sort of LEO credentials and get caught here using a blue light.
I know that in TX and OK any state DOT service vehicle will run any color light they want. Whether or not it is legal there I don't know, but they use every color there is on the same truck.
#899
Did a Lynard Skynard
Had my truck for about a year and a half now without a scratch so I guess I thought I would try a Lynard Skynard with an oak tree. Backing up extremely slow with the tailgate down and a bulky box on the tailgate on a dark morning I backed into an oak tree, in my own driveway to make it worse. Made me feel real smart, as the better half reaffirmed. Guess I got lucky and found a new take off the same color for $700. But I do have better things I could use $700 for. Will pick up the new tailgate tomorrow.
#900
