Clutch fork part number...
on
I have the engine out of my 69 F100 4WD - getting ready to put a 445 stroker into it. I am putting in a new clutch and I replaced the throw out bearing and noticed the clutch fork is pretty worn at the tips of the forks and the indentation where the release rod presses into it - not surprising on a 45 year old part. The dust boot is also pretty stiff.
I think I'd like to replace the fork, anti rattle spring, and dust boot but I'm not certain what part numbers will work for a 4WD.
on
And got a aftermarket dust boot.
Ps note one from a 302 is to small.
Orich
2WD/4WD makes no difference.
1965 F100/350 from serial number 600,001 / 1966/79 F100/350 (except 1977/79 F100/350 351M/400).
C3AZ-7515-C .. Clutch Fork - approx. 12.00" long / Reproduced by Carpenter.
1965/67 F100/350 240/300/352 / 1968/69 F100/350 240/300/302 (1969 F100)/360/390 / Ditto 1970 before serial number G30,001.
C6AZ-7562-A .. Anti-Rattle Spring / Obsolete
1965/72 F100/350.
GREEN SALES CO. in Cincinnati OH has 7 = 800-543-4959 / 513-731-3304.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 96 = 800-476-9653 / 704-786-8139.
on
C5TZ-7513-A .. Dust Shield / Reproduced by Carpenter.
1965/72 F100/350.
1965/72 F100/350.
Try this & see if anything matches.
https://www.npdlink.com/store/catalo...-130425-1.html
I just did the DC dust boot and it ripped apart trying to get it on, & I was being careful..
Dan
Dan
I wasn't able to find any at Ford dealers/obsolete parts vendors, but you might try Bronco Graveyard, because it was also used on 1966/68 Bronco 289; 1969 Bronco 302 (before serial number G30,001).
on
Bill, thanks for the suggestion. I looked through their inventory and they don't have any. Tried to call but their number is busy.
I know customizations are not your thing, but are any of the forks with the spring on the back the same shape and dimensions as the C3AZ-7515-C? I ask because I note that the pivot points are very similar in size - not having had both in my hands to compare I was wondering if it was a case that Ford replaced the anti-rattle spring with a spring clip on the back of the fork?
The anti-rattle spring was not used after 1972.
D0TZ-7515-A .. Clutch Fork / Obsolete
1970 F100/350 240/300/360/390 from serial number G30,001 / 1971/76 F100/350 240/300/302/360/390 / 1973/79 F100/150 302.
1977/78 F100/350 & Bronco 351M/400 / Ditto 1979 before serial number DG0,001.
1970 Bronco 302 from serial number G30,001 / 1971/77 Bronco 302.
1970 E100/300 240/300/302 from serial number G30,001 / 1971/74 E100/300 240/300/302.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
MILLER OBSOLETE PARTS in Binghamton NY has 3 = 607-722-5371.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 18 = 800-476-9653.
You could try this puppy, I don't have anything to compare it with, so it might work, might not. At one time NAPA had it, it's also available NOS
1970 E100/300 240/300/302 from serial number G30,001 / 1971/74 E100/300. 240/300/302.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 18 = 800-543-4959
These two places show the C8AZ7522A:
Nos Parts Source *Fo
913.220.5746
Part Number:C8AZ7522A
Seller:NOS Parts Ltd. - View ProfileDescription:BRACKET- CLUTCH RELEASE LEVER
Phone972) 937-2201
AND here is a C8AZ7522B:
Part Number:C8AZ-7522-B
Sellerennis Carpenter Ford Restoration Parts - View ProfileDescription:NOS** BRACKET
Phone800) 476-9653
Tell them you found it on RearCounter.comPrice:Request Pricing
Email:Send Seller Email Inquiry
AlsRyd66
08-12-2016 06:22 PM
gtowle
07-13-2016 08:50 AM
wmiller
03-01-2016 12:06 PM
billslk32
02-17-2014 03:24 PM
