1970 F600 Decode
F60 = F600 gas, 4x2
B = 300 1V six cylinder gas engine (probably HD version)
E = Mahwah assembly plant
H93333 = 1970 numerical series, April 1970 production
174 = 174 inch wheelbase
No color code. Note truck is a special order so the color could have been part of that.
F602 = F600 gas, 4x2, 20,000 lbs GVWR
4B8 = Black leather grain HD vinyl, standard cab.
A = New Process model 435 four speed transmission
64 = Rockwell model F-106 single speed rear axle, 15,000 lb capacity, 6.80 ratio
No front axle code. From '64 to '69 only optional axles were listed. All front axles were listed starting in 1970. So either you have a "carry over" of the no listing for a standard axle with a weight capacity of at least 5,000 lbs and no power steering, or you have something that was part of the Special Order. Those axles have some identifying letter/number marks cast in iirc.
20000 = 20,000 lbs GVWR
135 3500 = 135 certified net HP @ 3500 RPM
110732 (if I read that right)
11 = Boston District Sales Office
0732 = Special Order Number
Let me know if something doesn't match or if any more questions.
