2016 with 5500 miles in 500 mile DEF countdown
OK,
my 2016 F350 is in the 500 mile def countdown. Not sure why. There is 5500 miles on it. At about 3K miles, I got the under half full indication, so I put 2.5 gallons in, and it reset. Now at 5500, im getting the under 500 miles countdown, so I bought a couple 2.5 gallon jugs of DEF. Only one would go in. Countdown is still occurring.....
I know there have been prior posts, and will do that search now, but any quick ideas? I'm camping, am less than 500 miles from home, but dont want to be stranded...
In my 2011, when I got that message, I'd wait a little while then add a full 2.5 gallon jug. I read all the posts about confusing the system, and that I need to let it run down, then fill it, but never experienced it before. I hope thats all it is.
I checked mine at about 5000 miles and it said under half full...(which in reality didn't tell me shnit) At about 6200 miles I put a full 2.5 gallon jug in. room for more? probably but didn't have another jug to find out how much more. So am I just over half now? or am I 3/4 full, close to full? Fail on the DEF gauge Ford.
Ford really should put an accurate gauge in for the DEF fluid. Being such an integral factor in the emissions/exhaust system. If low fluid can put the truck into limp mode, it should have an accurate gauge. Like seriously... would anyone want a fuel gauge that just said, "Fuel tank is less than half full"?
I think all manufacturers in our truck segment fake actual DEF levels. It's a few sensors. I agree it's annoying.
My only advice is that when you fill it, fill it all the way so that you know you hit the top sensor. I've kept my topped off without issues, but usually I just let the below 1/2 full message hit and then I top it all the way off. Usually I can JUST about fit a 2.5 gal. jug in, if I can't, I drive it a little more and dump the rest in. Rather not have a little bit of DEF sitting in a big jug if I can help it. This is just my .02.
The reason, is that one time I had to go through several drive cycles before it reset the countdown to idle in my 2015. I only saw the 800 miles to empty in my 2011 once and it reset right away. (now of course it's 500) I was close to calling the dealer and then it reset.
This is something I think Ford could do a better job with - maybe they did with the 2017s, but something tells me that they left it alone.
If you get to zero It will derate. Obviously it will run dry and now you have a dry pump.
I don't let mine get that close but since I tow a lot I let it get down much closer and do a complete fill, taking almost 5 gallons.
Just seems to work better that way. You have plenty of warning with the count down.
Let the dealer reset it, and from now on fill the DEF when the truck tells you too (under 500 miles to empty). Make sure you fill it completely, it'll take close to 5 gallons.
I'm not real worried, its just different behavior than what i had with my 2011.
OK,
Got another "below half" notification on my vacation a couple weeks ago, bought a 2.5 gallon jug to fill it, and overflowed it again. From now on I'm going to drive it awhile on the "below half" notification before adding another jug.
Ford really should add a true gauge and float on the '17's for the DEF tank, but I doubt they will.
