1951 F-3 Panel Truck thread
My build project is getting this 1951 (according to registration) or 1952 (according to frame number) truck on the road. It's a F-3 frontend and frame with a cab custom made for military use. All wood on the inside.
It has no engine or transmission at the moment. And it's a low-cost project so whatever goes under the hood is going to be cheap and easy, at least for now.
Welcome! We look forward to learning more about your truck and your plans for it. There lots of helpful and very knowledgable folks on this forum. You have come to right place for help and support for whatever you might have in mind for your project.
I have a military 52 Ford panel as well. There are lots of pictures of it posted in my profile. Just click on my user name to access them. From the color, your truck looks to be army.
Add my welcome. Your profile says you live in Norway. I had assumed you were European (edit - more correctly Scandinavian) because all we've seen similar to your truck were from the Netherlands. We have I'll guess four or five members with similar trucks, but yours I believe is the only true panel bodied truck. The others are window vans having been ambulances or Civil Defense type trucks. Do you know if your truck has spent it's whole life in Norway?
All the others are 1951s, which your front sheet metal suggests yours is also. All the others are equipped with Marmon-Herrington all wheel drive. Does your truck have any signs of having been 4x4? Yours was originally a flathead 239 cubic inch V8 while all the others were 226 cubic inch inline six cylinders.
Below are pictures of three other members' trucks. The third one was originally a window van before the windows were covered. Stu
You're right about mine being army. It never left the area it was first stationed in until I bought it. Inland climate and very little road use in the last decades has saved it from getting too rusty.
No 4x4 on this. And the flathead V8 is long gone.
As I studied your picture I saw differences that suggested your truck began life as a Chassis/Cowl configuration. Below are the factory specification pages for it from the Ford Truck Handbook. These books were dealer/salesman references.
The R2 in your serial number, if it follows the USA pattern, is confusing. There is, of course, the prospect that the numbering sequence was entirely its own. We've seen in Canadian serial numbers, and those assigned to the Netherlands trucks I pictured, very different patterns than those used on our USA trucks. Ford had export production facilities in South Africa, Australia, Canada, and South America that I'm aware of. Perhaps other locations as well. Stu
The serial number sequence sure is close to the USA pattern. The sequence on the three pictured Dutch trucks is F3H1ABX-----. Very similar to your pattern, but with the "H" for the 226 I-6 engine and "1" for 1951. It would seem their factory assigned the ABX while yours assigned the CDX. Probably the X stands for Export. As for the 1951 sheet metal on a 1952 vehicle, we've seen other instances where Ford continued past year(s) styling on export models. Stu
This project has been on hold while choosing what methods to use and what equipment to buy. Suddenly I realised that winter was coming and I still had two pieces of panel simmering in a molasses bath. Got them out today so they won't be stuck in an ice cube waiting for spring. Molasses seems to be good for paint removal too.
Before and after pressure washer:
I was also wondering if I had widowmakers or not, i read about them too often on here to not get worried
These are mine:
These are mine:
I see that the tires are 7.50-17", so yes, I believe the wheels have to be Budd #49380 widow makers. We can't see the back sides to see the joints, but from the front they are clearly semi-drop center. If they are US made you'll find the Budd number on the back side rim lips. Replacements are hard to come by in the US, no doubt much harder in Norway. It would be logical to me that your better option would be to have the center discs remounted locally into new 17" one piece rims similar to what we've seen done by Stockton Wheel in California. Stu
IconDesign29
N. California Chapter
11-17-2013 07:18 PM
IconDesign29
1947 and Older Ford Trucks
11-05-2013 09:44 AM
rockin rebel
19
12-10-2010 11:16 AM
Campbell 56
02-16-2006 03:53 PM
