1987 F250 2WD 460 oil pump replacement
Driving down I81 yesterday, at about 65MPH, engine started back firing, and shut off. (has low oil pressure shut off switch). Pulled off to the shoulder, engine started - valves clattering Shut it down. Most things I can find on the search pertains to 4 WD. Question is, can the oil pump be replaced without removing the engine? I'm about 600 miles away from my shop right now. I know about the usual stuff, removing motor mount bolts, jacking engine, etc. But, haven't done a 460 before. Hopefully there won't be any bearing damage (doubtful).
86,000 miles with C-6 trans.
Thanks for any advice and help.
If your truck really has 87k on that motor, it's hard to believe that the oil pump just went out, itself.
They are beefy, in spec usually until something else forces an engine pull.
What's seems more likely, is either a broken oil pump drive shaft, or some other engine failure, possibly a bent pushrod, that allowed a lifter to leave it's bore.
You could pull the distributor, and take a look for the shaft.
If it seems intact, try the technique for priming an engine with priming drive rod on drill.
Or flatbed it home on a rail car.
Seems I have a lot of smog stuff left over.......
Reps to you TB460
+Roberta+
10-31-2010 07:38 PM
79F150400M
09-21-2009 09:41 AM
David White
08-21-2003 10:54 PM
