I had an HPOP line burst and soak the engine compartment with oil. I replaced the line and degreased the engine and rinsed it off. I started the truck and let it idle for 15 minutes or so before driving it. On the way home right after a shift it started chugging and running terribly. The check engine light was on as well. I limped it the mile or so home and shut it off. I restarted it and it runs just fine. I checked the DTC's with Forscan and there were a bunch of things that were mostly related to the HPOP and the MAT sensor that was shredded when the line blew. I left the hood open to dry out today and I'm hoping it is just some water in a connector. Does that sound plausible?
Yeah, oil level was topped off. Lost about 6 qts when it blew. I'll do light driving around see if it happens. I'll post the codes when I have a chance.
It wasn't a gradual power loss. It was like a light switch from accelerating smoothly to chugging.
