Towing a Class A Motorhome from the West Coast
I am looking at purchasing a 1962 Ford Condor Class A Motorhome. I will have to haul it from the West Coast to the East Coast with my F350. I think it will set too tall to haul it on my Flat. I am thinking of using a tow bar. I am unfamiliar with how they work or are mounted unfortunately. Can anyone enlighten me on the situation? How does it affect the steering of the motor home in tow if it doesn't have a locking steering column? All comments greatly appreciated. ...
when flat towing, you leave the steering wheel unlocked and the drive wheels will follow the path of the tow vehicle.
But...this motorhome, is it a standard or automatic? You may need to remove the driveshaft.
Another thing is brakes. You will need to get something to use the motorhome brakes to help you stop.
This motorhome won't run on its own power?
on
Flatbed it. Must faster, easier etc. The only thing you have to be worried about with flatbeding is how high will it be? Legal height is 13'6" to 14'. If you're under that height no problem. If it is over, then it time for permits and routing and all that.
If you're under, you're golden.
With that old of unit just drop the inside part of the unit and disconnect the wiring, it should be plugs going to the upper part and the 110 volts coming from the electrical panel. You will see 4 long bolts that hold the unit in place, remove them and the upper unit will just lift off. Use the foam gasket to to seal the hole with a piece of plywood.
Denny
Denny
That's real vintage unit - and one I had forgotten about. I did a quick search and came up with some interesting info - and one item is the height which is 9'2" without the a/c : 1963 Ford Condor Vintage Motorhome RV Motor Home - Tin Can Classifieds .
