no volts
Old May 14, 2016 | 08:14 PM
technocj's Avatar
technocj
no volts
My 85 e 150 manual trans has developed a problem. The van is not driven much, has 60 k miles, it did make a 1500 mile trip in April, no problem. The other day it would not turn over, just a click from the solenoid
. Battery is good, starter new, I checked cables for loose connection, it started.
This re occurred , and this time, no headlights, no power to anything. I changed the fusible link at the red power wire off the solenoid, removed a connector from the negative wire off battery terminal, it was green inside. I have power to the red wire off solenoid, ground is good. Is there another fusible link? The way this occurred, it seems like it should be a bad connection. I have manuals, but no wiring diagrams, hoping for some help.
Old May 15, 2016 | 08:03 AM
jimandnena's Avatar
jimandnena
Hi technocj,
Clean both battery terminals, remove the cables and wire brush. Next, follow the negative cable to the attachment on the engine block and remove and clean that. Measuring voltage is not accurate unless the connection is using maximum current as in starting. jim
Old May 16, 2016 | 08:34 PM
technocj's Avatar
technocj
Thanks for your advice. I had covered those bases, went over them again, and started looking further, found the hot wire wire at starter relay broken, insulation holding it together. Back on the road, I assume that was it, as I had immediate power to the fuse panel.
Old May 16, 2016 | 09:06 PM
jimandnena's Avatar
jimandnena
Good result, always glad to find a real cause with wiring problems!
Thanks for the followup. jim
geoff69a1
Jul 24, 2018 11:41 AM
aronsonk
Electrical Systems/Wiring
Aug 4, 2013 08:22 PM
red89F150
Feb 14, 2006 10:33 PM
fordgallor
Sep 27, 2004 07:32 PM
kacpam
Jun 9, 2003 09:17 AM
