1948 Ford F-4 rear end grind
My 1948 F4 (flathead V8, 4sp synchro, 5.83 rear) is having some major grinding issues in the back right hub.
Sounds like the bearings.
My questions is how do I remove the axel. My manual isn't too clear on the subject.
Also- any recommendations on other service I should do since I'm about to go deep in the back end?
I have the brake drum off and all the nuts removed from the axel.
Any help would be appreciated!
You will need to remove the nuts and tapered lock washers from the studs holding the axle in the hub. There are two jack screw holes in between two of the studs on the axle head, sometimes they work sometimes they don't. I have seen quite a number of axles with jack bolts twisted off in them. If the jack bolts don't pull the axle loose, you have two options, double nut the studs and remove all the studs or use a hammer about 3lbs and pound on the center of the axle head. Pounding on the head will cause the tapered lock washers to back out where you can remove them with pliers. Once the axle is loose, just pull it out. There is a pair of 8 sided nuts about 3 1/4" across the flats to adjust the wheel bearings. You will probably notice that a PO has removed the outside one with a cold chisel, very common, as most don't have the proper socket. There is a keyed washer between the nuts. When you get the hub off please notice that there is a snap ring behind the grease seal that must be removed before you can drive out the seal. I can give you the National and C/R numbers for the grease seals when you are ready to reassemble.
Mark
Mark
Thanks. Got it off.
Lots of metal glitter inside. Bearings done it seams...taking the nut off once o get the socket.
Mark
Mark
Should I be able to pull the hub off at this point?
Mark
Mark
It's not coming off easy.
I used pullers (pic) and no movement. Maybe I need to go farther but so far nothing.
I removed the nut without socket. It had the chisel notches .
BYW- Thanks very much for you help
I would SWAG that when the bearing cage broke, it locked the bearing and the inside race has worn into the housing. Look at the lower side of the housing where the bearing rides. From what I see, I believe you will find a 1/8" groove. If the race has worn much of a groove into the housing, you'll be looking for another rear end.
Top of the housing looks ok. How about the bottom side, where the pressure would be greatest? Look closely. Does the outside bearing inner race fit on the housing with no excessive play? What does the oil look like that was drained? Water, chunks? Now, inspect the other side.
New inner and outer bearings, races and seals will be on your list, minimum.
