A few weeks back, I noticed my driver side fog light housing broke. Granted the fog lights arent that bright anyways, I was thinking of replacing them with a light bar. Could I have the light bar wired up the same way? Would having a bar there cause the engine/tranny to overheat?
Yup...Rigid Industries has some DOT approved lights that work great. They even make a mount to place them in the factory location. I have the light in my bumper, really bright and over power the headlights so make sure you aim them correctly.
Yes I removed both of my fog lights and installed a 24" light bar. Can't remember what brand it is but its way brighter than the headlights and I re-used the original fog light wiring. The 10 amp fuse worked no problem.
Don't forget, any old LED won't be approved for on-road use, only offroad.
Stewart
After getting pulled over in TX by a state trooper because of my light bar; I wired in a dimmer switch so I can keep it low enough for highway use when needed.
Do you have a pic of how its mounted? And the electrical?
Any good offroad LED will be a bit pricey. Then you have Rigid which takes "pricey" and makes it astronomic.
Stewart
they look to be comparable in price to any other quality light.
maybe astronomically priced compared to crappy chicom Ebay lights but then again they produce astronomically more light
I have them in my bumper with the D2 spots and a 30" light bar. First...they are DOT approved, 1 ticket for having illegal lights will pay for them. Also, I am not a fan of all the cool kids driving down the Freeway/Hwy's with light bars on as fogs. This is stupid and very inconsiderate of other drivers. If you plan on just running the light on dark rural roads then have at it. But light bars are NOT for street use while other cars are on the road. That's my 2 cents...but my 10 cents is free. =0)
