Strange noise from transfer case region.
Okay, so I've got a bit of a problem. The other day I was driving out to the middle of nowhere to do some fishing. Everything was going smoothly until I turned down the gravel road toward the pond I was headed to. As soon as all four tires hit the gravel, I head what sounds like a grinding noise. At the time it sounded like it was coming from my front end. I parked the truck and got out to see if anything was out of place. Nothing looked wrong, so I got back in to see if it kept happening. I drove it down to the pond with no extra noise. I fished for a few hours, got back in my truck and went to drive off. As I pulled out onto the highway, it started doing it after about a mile. This time I was certain I wasn't crazy. I got under my truck. Looked to see if anything was out of place. Nothing looked inherently wrong. I shut the truck off, started it back up and started moving again. It didn't make the noise at first, but then after about half a mile it started back up. It sounded like my transfer case grinding. (My transfer case isn't in great shape, and if you done finesse it just right it'll let ya know.) I figured maybe it was left in four wheel drive because I let my dad use it to move a truck around in the backyard. I stopped again, cycled through 2h, 4h, N, 4l and then stuck it back in two high. Backed up and made sure my hubs were unlocked. They weren't locked to begin with. I started driving again and the noise quit. I drove it back home with no further noise. Then this morning as I'm going to work, it was completely silent under there until I got off the interstate. When I took off from the first red light, it started doing it again. It did it for another two miles or so before I made it to work. I lifted up my "boot" on my transfer case shifter, and it definitely sounds like it's coming from there or my driveshaft or somethin in that area. What do you guys think I should look at? It's not the original transmission or transfer case. I have an 89 f150 with a 351w, and it has a 1984 c6 transmission and I'm not sure exactly what type of transfer case. I just need to know if any of you have any sort of input on it because I'm completely stumped.
Borg Warner 13-56 case? Most likely shift fork failure, not unlikely that the oil pump failed already. It's quite likely it will soon get stuck in neutral, and you won't be going anywhere. They're not difficult to rebuild, but running around without a functional oil pump can make it not worth rebuilding. At that point, a good used case is a good option. Just crack it open to replace the oil pump & both shift forks, & do an oil pump retainer mod. Be good to go then for a couple hundred bucks. Likely no need to replace the chain, they're pretty stout for a half ton.
$350!? Ouch. You're in Mississippi and that's what t-cases go for? Round here (FL) they are $130 all day long at the yard. You sure you can't find a better deal?
Either way, you would be wise to crack open your new used t-case and do the oil pump retainer mod. That will make sure it lives a long happy life.
Yeah, I've been told $350 is pretty steep. I can't really afford to have my truck down for any longer than like a day though. I work Monday through Friday, and I've got no other vehicle available. I'd love to get one for cheaper, but right now this is the best option. According to the guy we're getting it from, it's apparently a damn good case. I'm hoping he isn't pulling my leg on this either.
jrotten67
02-23-2021 08:27 PM
Pwnm30rdi3
11-29-2010 06:15 AM
