6.2l with block heater
The purpose is to keep the engine warm when it's plugged in.
Well, you asked...
Most of the "cold weather" states new cars come standard with block heaters. Mine did up here in ND. I've never plugged mine in one time, and it always starts, but the coldest I ever started it was -40 F, and it started, but it did crank slow.
Well, you asked...
Standard issue on the trucks here in Wyoming. My opinion is that on cold nights, below 32 degrees F, it is easier on the truck if you plug it in as it keeps the oil warm. I try to keep mine in the garage when it is that cold but that is not always possible so I will plug mine in, especially when it gets below zero. I just think it is easier overall on the engine when starting it up.
Yes, as the temps go down, the current demands for starting (amps) go way up. But, at the same time, the ability of the battery to deliver that current is degraded. As the chart shows at 0F the battery is only at 40% but cranking demand is at 200% compared to 70F. All this assumes a serviceable, fully charged battery, good cables, no corrosion, a well tuned engine with good fuel no contamination, etc. A well charged battery is your best friend in cold weather.
In extreme cold it's better to bring the battery inside where it's warm and reinstall when needed. When parking overnight, even an unheated shed will lessen windchill and keep at least some of the latent heat inside the engine for easier starts the next morning.
Same here, my local dealer orders almost all the F250/350s with engine heater regardless of engine, I just figured it was a few extra bucks in their pocket. My F350 Platinum 6.2 has one.
