Tank troubles. Need advice
Hey guys. I've figured out what may be the root of all my problems (minus the poppet problems I'm having). I have white silt in my tanks, and it's getting slightly clogged at the pre filter screen on the fpr (dunno the actual name). But I know that's why my engine isn't getting the fuel it deserves. I am wondering if there is a single tank I can get for my truck. It's a shortbed. Or would you just recommend going with dual tanks? Also, should I replace lines while I'm at it? Other items to check? It's not getting fully clogged, nor is it getting past my fuel filter, so I know it's not getting into the engine itself, thank goodness. Any advice?
Boggin Dave
1996 f250 xlt 2wd auto 100,000
Boggin Dave
take off tank while empty, fill tank with few hand full of rocks and seafoam and shake it a lot, even better if you can put in bed of another truck and drive down some bumpy roads for a bit. then drain out rocks n rinse out well with solvent
I have done this on quite a few tanks ranging from 68 nova, tillers, tractors, street bikes, and more
I have my front tank out currently and am in the same situation. I got most of the crap out that had broken loose but there is significant rust and crap from the half way point and higher. Short of doing what Adam said and then sealing the holes and flipping it upside down, what would be the best way to get the crap off?
Dallas2142
08-07-2018 06:27 AM
old_beast
05-23-2016 06:00 AM
loosaloo
06-27-2012 09:41 AM
