1992 F150 351w build?
Unfortunately, the adapters are exactly what I need, but in my rush to over-complicate things, I looked right past them and dove head first into a Typhoon. By the time I came up for air, I realized all of the uppers are back ordered for months.
You probably made the right decision, adapting the 302 upper to a crap 351w lower would be my last choice.
It's great some folks are running a stroker on stock tune, but some run lean, for whatever reason, a wide band/ display should be added to the budget for assurance.
Gt40s off a mustang gt or explorer, even lightning (same thing), would be better than the e7 or e5s, depending on which truck engine you have, don't expect a miracle. The heads will crutch how much rpm you can get out of the engine but if your using it mainly sub 3k rpm for daily driving or off reading, won't be the end of the world, be torquey as a hell, just expect to eventually replace the heads...and cam...and stall...and....eventually wish you would have saved longer, tripled the budget, and built what you really wanted, the right way, the first time.
Add gears, tighten up the transmission....will make a difference....save another big pile of cash, build a 408, with the works, decide on SD or mass air, apply appropriate tuning software (even mass air needs to be tuned), then melt all four tires and be happy, that's my opinion.
There used to be adapters for upper to lower, went over like a lead ballon.
Intake to head adapters don't usually come up unless someone's trying to stick a roots blower on a 351w...or some unique 302 intake on a 351w.
Seems there's potential fitment issues at times, with the adapters, lower to head.
As with the ebay intakes, still some alignment issues at times but my money would still go to the ebay knockoff.
OP, hope you're okay if I ask this question to some of our extremely knowledgeable members here.
Would using this adapter and the 5.0 truck upper and lower intake which I already have, be a good choice? 5.8 GT40 lowers are hard to come by and costly, plus I would need an upper, TB, etc. to make it all work.
Price Motorsport has the adapters that you maybe referring to. If the link doesn't take you to the exact page, their adapter part number is AP-01. I've been contemplating getting this set to use on the 5.8 that i will swap into my truck. It currently has a 5.0 in it now.
I ran across this gem in the Bronco forum recently:
5.8L marine lower intake. Notice the port spacing....
Might be a worthwhile adventure to find one so you do not have to fiddle with the adapter route.
Thread: https://www.ford-trucks.com/forums/1...-new-user.html
I don't think you will build a stroker for $1,000, even if you do the wrench work yourself. I think I had about $3500 in mine, but I had a shop do everything. I do not recall the comp cam that was used, but it was an off the shelf CompuCam from them. I'm not saying that you can or should try to get away without a tune, but I am saying that I did it and didn't have any major issues. I agree with others on here; get your gearing straightened out first if you want to run big tires, and have realistic expectations. $1,000 will disappear quickly.
Previous truck was short lived but wicked fun. Built 302 with 373s (I think) stock tires. Not 100% sure what was done to it I got it that way and it would fly. My current truck tops out around 95ish takes a year to get there and stops in its tracks when it reaches there. (Using GPS speedo)
If I have to run a tune what's the average price?
I too ran across that a while ago looking for reasonable priced 5.8 lower... ()
But how much does that monster weigh?
I have a Explorer upper/lower & have been leaning toward the Price adapters the only real snag I see is trying to adapt linkage.
If something else presents its self, the GT-40 goes to my Mustang.
What injectors did you use? I'm starting to gather a parts list. Have the rotating assembly picked out, bearings are chosen, quoted a price for machine shop labor.
Looking at injectors, chip, and that's it I think. I'm gonna go to mustang heads or keep stock atleast for a while. Gears are already mine just have to pull them out of the donor truck.
#30
I was under the impression the stock injectors struggled for the stock motor let alone adding more displacement. I'm looking at a jet chip to go along with this & having it tuned (The shops near me don't seem to have a clue so I'm still hunting)
I don't see a lot in the way of tuning a SD system. It IS possible isn't it (Edit:To get a GOOD tune)? Is it difficult or do most feel its not worth the money?
