Sponsored by: Halo Lifts
2nd Gen EcoBoost up to 450lb/ft torque
Old 05-04-2016, 12:21 AM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
TFL went to Dearborn, Michigan to get inside at the 2nd Gen 3.5L Ecoboost. New block, same displacement (bore and stroke), same 365hp but upped to 450lb/ft of torque. Port injection as well as direct injection when needed. New turbos...just to give a taste. Plus the all new 10 speed automatic.
Old 05-04-2016, 05:14 AM
srb1194's Avatar
srb1194
srb1194 is offline
I'm excited now!!
Old 05-04-2016, 06:00 AM
Frdtrkrul's Avatar
Frdtrkrul
I'm hoping with the shorter block and all the short comings of the first generation EcoBoost this new one will be better. I'm also hoping the poet inectio. Won't add much more to the cost when the injectors need to be replaced and can be done without paying a shop to do it. Erring on the side of caution and not getting too excited as to be let down with more problems down the line. I'm still waiting on how the 10 year longevity will be on the engines, especially here in the rust belt.
Old 05-04-2016, 07:29 PM
Larietpsd's Avatar
Larietpsd
Larietpsd is offline
I know this may sound a little silly but the only thing about this trans that scares me is that gm was involved!! And I mean that
Old 05-04-2016, 07:46 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
I would assume the port injection is like Toyota's approach where the engine normally runs on the direct injection, but in certain situations, the port injectors are there to wash the PCV and EGR crud off the backs of the intake valves.
I would certainly feel better about this approach. The only problem with Ecoboosts is that they like premium gas to make their max horsepower, and the price diff between regular and premium is a LOT these days.
The 6 speed trans in front wheel drive applications (Escape, Edge, Explorer, Fusion) was also co-developed with GM. They seem to have been decent in terms of reliability. But 10 speeds in any automatic will make for a pretty complicated transmission.
Good stuff,
George
Old 05-04-2016, 07:56 PM
Larietpsd's Avatar
Larietpsd
Didn't know that about the current trans
Old 05-04-2016, 07:58 PM
Larietpsd's Avatar
Larietpsd
Doesn't the current 3.5 in the Lincoln already produce 460 or 480 on premium fuel?
Old 05-04-2016, 09:49 PM
Frdtrkrul's Avatar
Frdtrkrul
380hp and 460lb/ft with 91 octane.
Old 05-05-2016, 06:31 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
So, the new 3.5L EB is a forced induction, 10.5:1 C/R, 87 octane engine?
Damn..........that is impressive.
Old 05-05-2016, 06:35 AM
Larietpsd's Avatar
Larietpsd
I bet that torque number is on premium no doubt
Old 05-05-2016, 06:42 AM
redford's Avatar
redford
redford is offline
You're probably correct, but it is still impressive.
Old 05-05-2016, 06:47 AM
Frdtrkrul's Avatar
Frdtrkrul
If that's on 87, I wonder how much better it would be on 91 or 92 octane.
Old 05-05-2016, 07:10 AM
Tom's Avatar
Tom
Tom is offline
Nope, it's got the same 10.0:1 compression ratio the current one does.
https://media.ford.com/content/fordm...ter-boost.html
Old 05-05-2016, 07:23 AM
nojoke327's Avatar
nojoke327
nojoke327 is offline
All the interviews I've watched and read from Ford said the f150 will he 10.5:1 while the raptor gets 10:1
http://blog.caranddriver.com/deep-di...eed-automatic/
Old 05-05-2016, 07:53 AM
Tom's Avatar
Tom
Tom is offline
2017 Ford F-150 Gets New 3.5-liter Twin-Turbo V-6 and 10-Speed Auto ? News ? Car and Driver | Car and Driver Blog
It's odd...I've seen and heard the same thing without the Raptor disclaimer. The label at the center of that photo clearly says 10.0:1 compression ratio.
Quick Reply: 2nd Gen EcoBoost up to 450lb/ft torque
