The front end of my truck is sitting uneven. It leans to the passenger side. I measured it with a tape measure and there is roughly a 1.5 inch difference between the driver and passenger side fender well and the actual tire. Busted shock or a cracked leaf?
Did you look at the leaf springs to see if they were cracked? Shocks don't hold the truck up, so I don't think it's that. I would say a weak or broken leaf in the spring.
I glanced at it today. Didn't notice any I'm gonna get under it and inspect it a little better when this rain moves out. What's involved in replacing a front leaf? I go so many things I want to do to this truck and so little money. It's mechanically sound and runs awesome. It's just small routine maintenance things. Ball joints, front u joints, I need to pull the front diff and re seal it since it's leaking, new tires, and now possibly front leaf springs.
