OEM trailer brake controller 2015 expedition
Old 04-30-2016, 05:18 PM
95 taco's Avatar
95 taco
95 taco is offline
Recently picked up a 2015 expy EL for a family vehicle, it's an XLT with no tow package, part of the deal we worked with the dealer was that they would install the trailer break controller for cost+labor.
A few weeks ago they called and had the part in so they took the dash apart and installed it but according to the salesman the computer wouldn't recognize it so they took it out and left everything as is.
Doing some research today and I found out the newer F150s have to be reflashed after the TBC install so I would like to have them try that.
Would most techs be willing to try a refresh and see if the ECU would accept the TBC?
I picked up a hopkins 4 flat and 7 blade assembly that is supposed to plug directly into the OEM harness, it should work with the OEM TBC.
Old 04-30-2016, 08:28 PM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
That is exactly what should of happened.
A reflash of the pcm. They have to enable it.
I'd go back to them.
Old 05-01-2016, 06:11 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Hard for folks here to say what someone at a dealership would do. I would talk to them and ask.
Steve
Old 05-01-2016, 12:53 PM
95 taco's Avatar
95 taco
95 taco is offline
Cool, I'll make an appointment and talk directly to the tech rather than the salesman.
Steve
If the dealer we bought from won't play ball then I'll probably take it to the dealer that I used to work for, we had some good techs.
Old 11-17-2017, 08:16 PM
pssdas's Avatar
pssdas
pssdas is offline
pssdas
Did the discussed fix work? I have a 2015 Ford expedition XLT without the factory brake controller. I took it to the dealer to have it connected and they were not able to do it so I wonder if this will work. Thanks for your help.
Old 10-28-2018, 09:44 AM
rxe121's Avatar
rxe121
rxe121 is offline
OEM TBC foe Expedition
Hi, I'm also interested to see if the dealer could flash the computer and get the OEM TBC to work. I have a 2017 Expedition XLT that did not come with the tow package but all the right fuses in the fuse box. I wired a 7 blade trailer adapter on the back and would like to install an OEM brake controller.
Old 10-30-2018, 09:45 PM
pssdas's Avatar
pssdas
pssdas is offline
Of the two dealers that I tried to work with neither one was able to guarantee what I was suggesting woodwork. I had even contacted ford service and they would not guarantee that it would work. They told me to contact the dealer can give them a service number. I finally just put in the prodigy three brake controller in it seems to be working fine.
Old 12-15-2018, 06:52 AM
87crewdually's Avatar
87crewdually
87crewdually is offline
I don't see how anyone else made out but I just got a quote for the TBC to be installed on my work truck. It's a 2017 Expedition EcoBoost. I removed the cubby panel and the plug is in the dash for the controller. I've checked the module with Forscan and the TBC can be turned on so I should be good to go. This truck didn't come with the 7 round plug just a flat4 plug so the quote has listed the adapter plug/pigtail. The new receptacle is specific to Expedition and has both flat4 & 7 round RV plug.
Now I wait for approval to get it done.
dnewton3
2017+ Super Duty
04-08-2018 05:58 PM
nickh420
2015 - 2020 F150
12-12-2017 11:00 AM
vnleclaire
2015 - 2020 F150
11-21-2017 04:23 PM
Celtictexan
1999 to 2016 Super Duty
07-24-2017 07:45 PM
Resqguy77
2009 - 2014 F150
12-01-2015 11:08 AM
Quick Reply: OEM trailer brake controller 2015 expedition
