1989 ford f150- Fuel pump location?
Old 07-29-2007, 09:20 PM
william7's Avatar
william7
william7 is offline
1989 ford f150
where can i locate the fuel pump on my 1989 ford f 150
Old 07-30-2007, 03:26 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Hi and Welcome to FTE! These guys in here ('87-'96 F-150 forum) should be able to help with your fuel pump question.....
...Thread moved
Old 07-30-2007, 03:50 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
one in tank and one along the frame rail.
Old 07-30-2007, 03:55 PM
meatloaf87's Avatar
meatloaf87
meatloaf87 is offline
i think that the fuel pump is on the iner fram rail just under the drivers door.
Old 07-30-2007, 06:06 PM
mclarenryder's Avatar
mclarenryder
mclarenryder is offline
Post hide and seek fuel pumps
f-series 1/2 have two fuel pumps on the single tank system. a low pressure sump pump is located in the tank, this is where your fuel sending unit is attached. its also the one that usually goes out. the second one is a high pressure, constant flow pump that sends pressurized fuel to the engine and sends excess fuel back to the fuel tank to maintain constant fuel fuel and pressure.
whats wrong with ur fuel pump?
Old 07-30-2007, 07:26 PM
Conanski's Avatar
Conanski
Conanski is offline
You could just have high pressure pumps in the tank/s as well...
Old 07-30-2007, 07:50 PM
quicklook2's Avatar
quicklook2
for that year he has low in tank and high on rail.
1990 on have the hi pump in tank.
Old 01-15-2016, 02:58 PM
Jimmy Bonnette's Avatar
Jimmy Bonnette
Jimmy Bonnette is offline
Is there pumps in the tank when u got two tanks
Old 01-15-2016, 03:20 PM
88n94's Avatar
88n94
88n94 is offline
Yes, if you have fuel injection. Tell us what year your truck is and what engine you have, and we can explain what you got.
Old 04-30-2016, 02:27 PM
jlp50's Avatar
jlp50
jlp50 is offline
Fuel Pump Location
I have an '89 Ford F150 xlt lariat 2 wheel drive with 2 gas tanks its a straight 6 4.9l. I was trying to find the location of my fuel pump.
Old 04-30-2016, 04:24 PM
88n94's Avatar
88n94
88n94 is offline
You actually have 3 fuel pumps. One in each gas tank and one in the frame rail, roughly under where the driver sits.
ShakeyJC
10-01-2017 04:15 PM
siyksoul
74
06-25-2017 04:19 AM
tnab1970
04-21-2017 08:11 AM
FordMac1
12-22-2016 09:08 AM
seagiant
WTB - Parts & other
02-17-2016 08:21 PM
Quick Reply: 1989 ford f150- Fuel pump location?
