wiring - fusebox replacement
I may be swapping in the under-dash wiring from a 68-69 to replace the cut up one wiring harness my 71 and to make it easier to connect the f600 instrument cluster.
The fuse box is the only thing messed up on the replacement harness. It just as a plastic piece busted and is usable. This would be a good time to perhaps improve that fuse panel. Any simple and inexpensive off-the-shelf options one would recommend?
so what's your definition of inexpensive? how about this?
Painless Performance Universal Fuse Blocks 30001 - Free Shipping on Orders Over $99 at Summit Racing
on
The EZ wiring harness I purchased off Evilbay, came with a fuse panel, each circuit labeled, and with extra fuses. It was not very complicated to install. If you are looking for just a fuse panel, try some of the marine stores, or the West Marine catalog on line, and you may find one that will fit your needs. Of course, the marine versions may, and probably will, be a bit more Spendy, (if that is a word), but the quality will be superior to automotive versions. Or, at least the price will make you think so. I call Marine stores, Jewelry Stores, due to the prices..
I will check with Allied Electronics, as our daughter is a mid level manager at the Dallas/Fort Worth plant. They are the 3rd. largest electronic company in the world, so it could be a good shot?? You never know...
Baja
Baja
I checked Dell City, the place I ordered my connection blocks, and they did not show anything. Will see what the marine store has. Used to haunt those places when I was redoing a 22 foot Southcoast sailboat.
It's not that big of a deal. Just seems like an opportune time to make an improvement if reasonable.
I got mine from a 79 F350 in the junk yard. I got the panel cover too, it list which fuse goes to what. I haven't installed it yet. It's just a bigger version of the original. It has 18 blade type fuses instead of glass. That should be enough for most trucks. Just mark the wires before you start cutting your old fuse panel out. Switch the wires over to the new fuse panel, mount it and call it a day basicly.
This is what I went with and also a relay box next to it and for a great price
Also I have two of them mounted. One under the dash and one under the hood next to the relay box. I don't think all the power needs to be loaded under the dash that's why I did it that way and it's a boat fuse panel which = water proof
Amazon.com : Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover : Fuse Block With Relay : Sports & Outdoors
I just grounded it to some cleaned and bare metal next to the fuse box for a extra ground. The more good grounds you have on the body and frame the better electrical current you will have. A buddy of mine use to own a stereo and when they installed high power competition systems they would ground the car body to frame and electrical system at least at 18 points across the car to keep the power flow smooth with the draw that was happening and none of his cars ever has power surges that made any light dim or anything and the systems they put in some cars was just ridiculous in my opinion lol
Also the link I added to amazon should show tons of electrical components. I have purchased all my electrical connectors and such (modern connectors) off amazon and the prices are the best. I personally just look through and get marine items more then automotive because I like my electrical to be water proof. Makes pressure washing the truck everywhere less of a concern
