Fuel pressure gauge?
Old 04-28-2016, 07:20 PM
Zachsquatch
Zachsquatch is offline
Zachsquatch is starting off with a positive reputation.
Hey guys, I am not looking for anything super fancy but I was wondering what kind of fuel pressure gauges people might be running or using for diagnostic purposes.
Thanks.
(Late 99 F-250 XLT)
Old 04-28-2016, 08:05 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
For diagnostic purposes, you can plumb a 0 - 100 psi gauge into the fuel bowl and duct tape it to the outside of the windshield.
If you just want to keep an eye on things, you can either get a dedicated gauge, or a digital gauge/monitor that can see different inputs after you add a fuel pressure sending unit.
I've got an Aeroforce scangauge and sending unit that will monitor fuel pressure, as well as many other inputs.
Old 04-28-2016, 08:48 PM
Zachsquatch
I was looking at both options. I picked up a cheapo gauge that I plumbed into the fuel bowl with the adapter fitting and the schrader valve from Dieselorings. The only problems with that set up is it has a very short hose and it's a piece of crap gauge which fills with fuel and then leaks, lol.
Does anyone have a source for a manual gauge like I described? Since I have the adapter/schrader valve already it would be pretty simple to hook one up. I need one with a decent size hose and of good quality.
Thanks for the input F350-6.
Old 04-28-2016, 09:18 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
If it's your truck I'd recommend going all in on that and installing a permanent gauge. 99% of the time it's just confirming that all is well, but when the engine stumbles it can quickly solve half the diagnostics. Top drawer Isspro EV2 setup only $130.
Isn't your baby worth it?
Old 04-28-2016, 11:51 PM
Zachsquatch
Lol, my baby sure is worth it....my actual baby which is on the way. Rofl and my other one already here. That's currently where my money goes. But I do agree with what you're saying, the fuel pressure on these beasts is so crucial it pays to have something constant to reference.
All the info and advice for this is a positive and it's these kind of suggestions that I do want, so thank you for your input I'll keep that in mind for down the road when I get a few more things fixed up on the truck. Believe me if I had the dough I'd invest in the good stuff.
Old 04-29-2016, 08:37 AM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
Rikster-7700 has a very good reputation on FTE.Rikster-7700 has a very good reputation on FTE.Rikster-7700 has a very good reputation on FTE.Rikster-7700 has a very good reputation on FTE.
I use glow shift gauges, they do get bashed by people, but they are a cheaper alternative and I have had no issues out of mine in the two years I have had them installed.
Old 04-29-2016, 11:19 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.
Good to read this . I'm thinking about picking up one of their fuel pressure gauges.Any pics of your set up?
Old 04-29-2016, 01:44 PM
Traildust's Avatar
Traildust
Traildust is offline
Traildust has a good reputation on FTE.Traildust has a good reputation on FTE.
I also went with a GlowShift Max Tow fuel pressure gauge and have had no problems with it for over one year it's been installed. I did have some installation questions about dimming the gauge and called GlowShift, they were very helpful and professional to talk with.
Bill
Old 04-29-2016, 01:58 PM
Zachsquatch
Awesome, thanks. I'll check into them. I would also like to see pics of people's gauge setup, it may help me pull the trigger on one of these options.
Old 04-29-2016, 03:08 PM
ebbnflow's Avatar
ebbnflow
ebbnflow is offline
ebbnflow is gaining momentum as a positive member of FTE.
My glow shift gauges work great, but I'm on my 3rd fuel pressure sensor and my second oil pressure sensor. The fuel pressure sensor is good for about a year and starts reading high (100 psi) when it goes bad. Oil pressure sensor lasted 2.5 years and reads low (0 psi) when it goes bad.
Old 04-29-2016, 04:24 PM
Traildust's Avatar
Traildust
That's some good information to have.
Bil
Old 04-29-2016, 04:38 PM
Rikster-7700
Sorry had to get off work before I could snap a pic. The top one is the fuel pressure then the trans temp, boost and finally EGT. I got the set, and the pod off amazon. It wasn't too bad a price at all if I remember correctly.
Old 04-29-2016, 04:44 PM
Rikster-7700
Not sure if the pic uploaded from the GT app. Please let me know if it didn't?
Old 04-29-2016, 05:32 PM
dn29626's Avatar
dn29626
dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
I do not see any pictures.
Old 04-29-2016, 08:46 PM
Zachsquatch
Hey Rikster, I don't see a pic either. Thanks for the info guys.
Quick Reply: Fuel pressure gauge?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
