Much too common on these motors. The intake design wasn't Ford's finest hour. jim
The V10's used a cast metal intake, correct? V8 Modular Motors have the plastic version, also prone to issues though more of cracking and causing air metering issues--have not seen too many reporting coolant leaking into the cylinders.
Intake is in fact cast aluminum. I have to take responsibility for this failure as my cooling system maintenance routines have been less than perfect. I change the oils and filters regularly but I need to be more diligent with the cooling systems. Lesson learned!
Hmmmm... Exactly how bad was your lack of maintenance on the cooling system?
Et al:
https://www.ford-trucks.com/forums/1433323-under-maintenanced.html
I missed the last two coolant changes. Last one I did was at 75000. I'm embarrassed! I didn't put many miles a year on after 75000 so it just slipped by me, my fault!
More specifically if you don't mind...
How many miles?
I ask because I've added 140,000 miles to mine in the last 3 years and not changed the coolant....
I'm not sure I've even looked at the reservoir level...
