To flare or not to flare, that is the question...
I run 0 offset 20x9 wheel and the 37x12.50 sits inside factory flare. 3.5" lift
The rockers are taking a beating from rocks, I don't run low rider steps either.
ZooDad...it's a Full Lotus. They are one of the nicest around
Full Lotus Recreational Decks
Im in the same boat, If I was worried about rock chips, mud, and dirt I wouldn't have gotten wheels that stick out past the stock fender and off road tires. IMO unless on the right truck they just don't look good
thejean....I was a Police Officer in So. Cal. for 33 yrs. and as you know "technically" you are illegal with the tires hanging out like that. I wasn't big on writing cites (we had much more important things to handle) but a traffic guy? that's his bread and butter.
I don't know where you live but for everyones sake including your trucks.....YES, run the flares which will make it look much better, kind of "beefier"......and some type of mudflap. The 3m tape will be a good addition. Good luck.....Dave
Edit: I also just put these tires on and took off my old mud flaps so I could test fit the flares. I've only taken the truck once in its current obnoxious state! Haha!
thejean....I've built several hot rods over the years and one thing that every gear head finds out sooner or later.... you never stop spending money on them........ and yes, those lifted trucks with the flares and big weenies do look nice. Also, once you get the lift done don't forget to adjust your headlights or might see Ofcr. Fred Freindly in your rearview mirror .........Dave
#29
#30
