Intro - 1950 F47 (F1) - Page 2 - Ford Truck Enthusiasts Forums
Old 08-29-2016, 11:12 PM
KirkF's Avatar
KirkF
KirkF is offline
KirkF has a good reputation on FTE.KirkF has a good reputation on FTE.
In this picture you can see where I cleaned up the transmission. The original ford paint colour is visible on it. Anyone know what colour that is?
(note the larger oil filter that came standard on Canadian V8s)
Also note the visible bend in the frame on the passenger side, just behind the transmission mount.
Old 08-29-2016, 11:17 PM
KirkF's Avatar
KirkF
KirkF is offline
I removed the brake master cylinder, pedal assembly and drive shaft.
The next step will be to pull the motor and transmission out.
After which I can work on removing the rest of the suspension.
The end goal is to get the frame completely stripped down, so it can be straightened and welded up.
Old 08-29-2016, 11:52 PM
KirkF's Avatar
KirkF
KirkF is offline
A short video of the engine briefly running:
(also my first youtube upload)
Kirk
Old 08-31-2016, 12:31 AM
KirkF's Avatar
KirkF
KirkF is offline
Tonight I removed the engine and transmission from the frame.
Just a little more stuff to strip off and then the frame can go over to a frame shop to hopefully be straightened, and the cracks repaired.
Old 08-31-2016, 07:48 AM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
The tranny looks yellow to me, similar to the yellow that the 55 and 56 engines were painted. Have you found any paint on the engine block?
Old 08-31-2016, 09:04 AM
ben73058's Avatar
ben73058
ben73058 is offline
ben73058 is a splendid one to beholdben73058 is a splendid one to beholdben73058 is a splendid one to beholdben73058 is a splendid one to beholdben73058 is a splendid one to beholdben73058 is a splendid one to beholdben73058 is a splendid one to behold
Hey Kirk,
You are making short work of stripping that down! It still looks pretty solid. So.. How long
has it been since that engine fired up? Are you making any changes to it or is going back together stock?
I see a couple of other projects lurking over there on the side of the garage...What could it be?
Looking good up there in Manitoba!
Ben in Austin
1950 F1
Old 09-01-2016, 12:32 PM
KirkF's Avatar
KirkF
KirkF is offline
ABE,
The beige engine and transmission colour is unique to the Canadian V8s.
(And I can't say I like it much) I have read that all the Canadian trucks were made with V8s and larger oil filters to meet the Canadian military spec at the time. The beige paint might be due to that, or because FORD had a pile of spare paint after the war. Who knows.
I found this video on you tube which shows the colour.
Kirk
Old 09-01-2016, 12:35 PM
KirkF's Avatar
KirkF
KirkF is offline
Thanx, Ben,
Sadly the shop and all the other projects in it aren't mine. A buddy was kind enough to let me use up a third of his new shop for this project. I need to keep things moving or he will get bored of it and kick me out into the field. Lol.
I don't think that motor was started since the 1970s. The plate on the vehicle was from 1974.
Old 09-06-2016, 05:06 PM
KirkF's Avatar
KirkF
KirkF is offline
Motor on engine stand.
I have no idea why jobs that I think should take 10 minutes, end up requiring a trip to two hardware stores and three hours.
Old 09-06-2016, 05:12 PM
KirkF's Avatar
KirkF
KirkF is offline
I removed the oil filter, exhaust manifiolds, fan, distributor, generator etc, and split off the oil pan.
No real surprises in the oil pan. Some sludge, but no metal pieces.
The oil filter however was much worse. The intake feed line had a nail in it blocking it off, and the whole filter was full of sludge and the lines were blocked by sludge. (You can see in the picture the nail that was inserted in the line held in my blue glove)
I have no idea why the PO did that. Maybe they didn't like oil filters. Maybe they had low oil pressure and wanted to boost it. Who knows.
Note the Made In Canada Fram Oil Filter. Like a lot of other things, that manufacturing has been shipped somewhere else.
Old 09-06-2016, 09:44 PM
Corner Gas's Avatar
Corner Gas
Corner Gas is offline
Corner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant future
That nail in the oil line is odd.
Old 09-06-2016, 09:49 PM
KirkF's Avatar
KirkF
KirkF is offline
Yes its very odd. Its a perfect fit to let you block off the oil feed line, and put the fitting back on.
All I can think of is they didn't want to lose any oil pressure through the filter.
Kirk
  #28
Old 09-09-2016, 08:30 PM
Corner Gas's Avatar
Corner Gas
After my truck is warmed up the oil pressure is about 10 - 12 when idling but, going down the road the psi is around 30.
  #29
Old 09-12-2016, 05:58 PM
KirkF's Avatar
KirkF
KirkF is offline
Continued stripping down the motor.
The valves on #2 cylinder were VERY stuck open. Which explains some of the backfiring during my attempts to start it the one time.
The oil pump is incredibly stuck in place. I can move it up and down about 1/16th of an inch and that's it. No idea what's holding it in place.
I've read some other posts where people have had a really difficult time with removing them.
I'm a little short on pictures for this part. I should have taken more.
Kirk
  #30
Old 09-12-2016, 09:03 PM
Don T
Don T is offline
Don T is starting off with a positive reputation.
paint color of trans
Mine is 51 Canadian Merc F3, 8BA, color of engine and tranny are similar to yours. The closest I could find locally was a almost gold engine paint from crappy tire. What is interesting is that under the gold/yellow paint is "Ford blue". This is a origional motor ,not a rebuild. Re your box, it appears the Canadian plants used what was on the shelf as many parts on mine are not correct but I know they are origional. Go figure. The oil pump will come out, just 65 years holding it back.
Quick Reply: Intro - 1950 F47 (F1)
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
